John Rogers's Avatar
Things I Have Learned about 914s...What are your secrets?
Having owned 914s for a few years now I have gathered a list of NICE things to remember, such as:
1 - If the D-Jet engine starts to run ragged, replace the FI points FIRST. Every time this has happened the FI points happened to be the cure.
2 - Back firing can be caused by broken exhaust studs. Have them all replaced with the large ones immediately.
3 - If #2 was not the cause, check the injector seals and plastic caps if they are missing? Missing caps will let the injector flop around in the small seal and cause air leaks.
4 - If fuse #9 blows, check the backup light wires. If they are okay, check the wires to the gauges for fraying or see if the PO had added accessories to the inner lug at fuse #9.
5 - Check vacuum hoses yearly for hardening and cracks at the ends. At the same time clean out the PCV valve and reseal the oil filler to the block as the cork gasket will harden.
6 - Make sure all the seals around the tin are good, especially true in So Cal.
7 - Make a jumper so you can bypass the fuel pump start relay at pins 30 to 87 so you can get home. This will cause the pump to run when the key is on. I also have a set of 3 for our 1987 930.
Do you have any to add?????
Old 08-12-2004, 03:49 PM
GregD's Avatar
If you are going on a long run in the mountains and have changed your fuel gauge because you replaced the combo, make sure you either have it calibrated, or know when it is close to empty... Not me, but a friend
Greg DeBord
PCA Member
73 914/6 conversion
83 944 (newest addition)
99 996 aero coupe
Old 08-12-2004, 06:27 PM
Wash the car at least once a week - cause, you want to look good - don't you?
Oh yeah, if your clutch cable breaks at midnight in the middle of the night, in the Santa Cruz Mountains - you can still make it home double clutching & starting the car in 1st gear. But, a spare clutch cable would have come in handy.
Old 08-12-2004, 06:48 PM
Here's one: They make a**-kicking race cars. Buy a spare one and make the leap!
Don Newton
“People sleep peaceably in their beds at night,” George Orwell wrote, “only because rough men stand ready to do violence on their behalf.”
"I gave up visiting my psychoanalyst because he was meddling too much in my private life." Tennessee Williams
Old 08-12-2004, 08:52 PM
SGB SGB is offline
SGB's Avatar
Angry It is usually a bad ground.
-Scott
My gallery page
Old 08-12-2004, 08:54 PM
well my list is short:
i keep one of those 2 dollar auto testers with a light bulb in it
works great for everything including finding loose grounds, to figuring why that damn fuse blows
also a few peices of wire with alagator clips of the end to bypass anything that needs it ( i once had it to my fuel pump from my headlight when a wire broke off under the gas tank )
i even keep a butane soildering iron in the car
oh dont forget the 30 lb tool box with the AAA card in it ( that way after the 30 lbs of tools dont fix it the card is right in front of me )
scott thacher
75 914 with 2.5 l 98 suby engine on the road
Old 08-12-2004, 09:40 PM
Kenny Powell's Avatar
Okay John,
I think I got a good one...the 914 comes with 2 free round relay tester's(black one's) as per test of relay board. they are the socket's that run the Headlights( if it makes your head lights pop up! it(relay) is good.
75' 2.0 w Ljet
"I like the way she doesn't move in the curve's... and then she let's go!"
Old 08-12-2004, 11:38 PM
SGB SGB is offline
SGB's Avatar
Actually the most valuable trick I have is the hole I drilled at the top edge of my spark plug socket so I can hook it with a piece of stiff wire. I can't get one of those T-handle type to fit around my intake manifold on one cylinder. When I put in new plugs and pull the socket extension, it always seperates from the socket (leaving the socket on the plug below the top of the cooling tin). So I drilled that hole, and and yank it out with the wire handle part of a really big binder clip.
Also-
always try a 13mm first.
Expect ot take off at least one tire to do ANYTHING.
Remember to clean and relube that clutch cable pully.
-Scott
My gallery page
Old 08-13-2004, 07:54 AM
Oh let's see...
I probably have a couple to add (now that im on my 16th year of ownership)....
1) dont throw away rear brake calipers.
2) the ebrake will eventually sieze up on you... dont use it if you dont have to? (i know that sounds like bad advice)
3) YES... keep an extra clutch cable in the car. Mine go like clockwork every 3-4 years.
4) Make sure coil is secured tightly... i've seen them spin in place and rip the wiring from the engine.
5) for 1.8s... INSPECT the fuel injection resistors FIRST if all of a sudden your car feels like its running on 3
6) Replace that old rusty double relay
7) Replace all the shift linkage bushings immediately for a brand new feel and better response
8) Name your oil leaks.... they become family after awhile.
9) Compufire - enough said.
74-1.8 (sold)
86-944 turbo (sold)
97-M3 coupe (sold)
03-M3
http://www.pelicanparts.com/gallery/castlesteve/
Old 08-13-2004, 08:05 AM
Conrad W Peden's Avatar
Whack the starter solenoid.
We'll be having an ISO9000 audit soon.
I've divided our preparation tasks into two groups: Unethical and Unproductive.
Old 08-13-2004, 09:38 AM
norustscott's Avatar
Rust free 914's have rust and are never free. I will bet even the Ferdinand 8 in the museum has rust...
Scott
1982 911 SC
1962 sunroof bug
1991 WE Vanagon CARAT WRX conversion
Old 08-13-2004, 11:30 AM
Member w/ Title Problems
Jason Porter's Avatar
Throughout my 914 ownership I learned there is no such thing as a trouble-free 914. They aren't totally reliable.
As a fix-it motivated kinda guy, I always got there, but I was sometimes dirty from working on my car, so I made this rule:
ALWAYS CARRY ONE SET OF CLOTHES WITH YOU THAT ARE PRE-APPROVED BY YOUR WIFE FOR FIXIN'.
2023 Ford F-150 Platinum 5.0 Coyote FX4
2019 Toyota Sienna XLE AWD
Metal Building Erector, Recovering Porsche Guy
Old 08-16-2004, 09:40 AM
- The stock starters are lame and should be replaced immediately with a Tilton High torque starter. You will never have another hot start problem again.
- When you have problems, check the basics. Do I have spark? Do I have fuel? Do I have 12v at the device? Is my ground good? These cars are getting old and you shouldn't assume anything is good.
- Always have a current AAA card or respective towing service. 914's are a lot of fun but reliable they aren't. The AAA card will give you the confidence to take the car out for drives because you will know you will get home one way or the other.
Rob
'90 964 Cabrio - daily driver 220K miles
Old 08-16-2004, 10:54 AM
iamchappy's Avatar
When installing spark plugs attach a 6 inch or longer length of hose to the insulator, when the plug threads in tight enough that the hose slips on the insulator pull the hose off and tighten it up the rest of the way with your wrench.
The hose allows good feel and prevents cross threading or stripping, and also eliminates the possibility of losing or dropping the plug.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 08-16-2004, 07:10 PM
3D914's Avatar
I have a few:
1) Always use an engine lift of some kind to remove/install the engine.
2) Always inspect the cooling fan at service intervals - some strange things can get stuck in there.
3) If you get tired of trying to diagnose FI problems, don't go to carbs - just update the FI system to something more modern with sensor feedback.
4) Check tire pressure at regular intervals - just because you don't hear the tires squeel, doesn't mean you not spinning out.
5) Despite what people may say - you can use your 914 as a truck. Few cars have a 4ft x 4ft trunk with a lid that opens nearly vertically.
6) Despite what people may say - a 914 can be reliable enough to drive on 3500 mile trips.
Gerard
74-914 White - Soon to be a custom 3.2L Six 87-924S 2.5L Artic White - SOLD 74-914 2.0L Ravenna Green - SOLD
Old 08-18-2004, 12:19 PM
