914/6 Conv front sway bar size
HI,
I am doing a 914/6 conversion for street/AutoX. I have 911SC front struts, and will be puting 7X15 wheels front, 8X15 in rear. What would be the recommended front sway bar size 19 or 22 mm?
Thanks,
Ted
Old 08-18-2004, 05:12 AM
BURN-BROS's Avatar
Ted, welcome aboard. Whats your engine size and h.p.?
Congrats on the conversion. I hope it goes well for you.
Aaron
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 08-18-2004, 06:18 AM
Acox914's Avatar
Send a message via AIM to Acox914
buy the biggest one. you can always set it soft. if you buy the small one, and max it out, and find you need more anti swaybar....youre screwed.
several choices only limited by your budget:
Weltmeister
Tarett
Racers Group
Smart Racing
?charlie bar? (not sure on this one)
-Aaron
"60% of the time, it works every time"
Old 08-18-2004, 09:01 AM
914 Geek
The rest of the suspension will also influence how much front roll stiffness you need. So will the desired alignment settings (which will also be inflenced by the suspension setup and front ARB size), driving style, and so on...
--DD
Old 08-18-2004, 10:33 AM
OCD project capitan
BigD9146gt's Avatar
22mm.
Don Welch
'73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper.
Old 08-18-2004, 08:23 PM
mskala's Avatar
I disagree with these guys. If you are interested in
autocross, and you don't have a rear limited-slip,
then you don't want a rear sway bar. And you
probably want 21mm torsion bars and 180 lb rear
springs (or similar). With this setup, I run the small
front sway bar (welt 19mm) FULL SOFT for autocross,
to minimize understeer at low speed.
If you run a bigger bar, you won't be able to soften it
enough. I also drive my car around on the street and
it is okay with these settings.
Mark S.
'70 914-6
Old 08-19-2004, 09:14 AM
OCD project capitan
BigD9146gt's Avatar
Mskala is right, you want lots of body roll for autocross. For street driving though, i would have the 22mm sway bar because if you max out the 19mm, you need to buy the 22mm.
For autocross, like mskala said, use the big torsion bars and 165 or 180 springs in the rear, and simply dissconnect the sway bar to acheave more body roll.
Don Welch
Old 08-19-2004, 11:26 AM
One "sweet spot" for the 914 is:
Stock front T bars
140 lb rear springs
19 mm front AR bar set full soft.
This is a good compromise street/AX set up.
That was one of my "stops" along the way.
My car is now pretty much a AX only car.
21mm T bars
25 mm Tarret AR bar (effectivly a 22 mm bar cause it's hollow)
set full soft
225 lb rear springs.....and I'm gonna need stiffer...I still have a push that I'm having to drive around.
I run the same size f&r tiars, so this may skew things a bit for someone with fat rears.
This is NOT a comfortable ride....but it corners fairly flat. .......
JPIII
Early Boxster
Old 08-19-2004, 01:26 PM
Best I can recall, this pic is with the "sweet spot" suspenders. &
smaller front tiars. ......
JPIII
Early Boxster
Old 08-19-2004, 02:14 PM
