Send a message via AIM to karaoke_carlos Send a message via Yahoo to karaoke_carlos
Replacing brake lines
I just got a new set of brake lines from Pelican. Unfortunately, I'm having a hard time reaching the top nuts on the left side (haven't even tried the right yet). ANybody have a tip/suggestion?
Thanks,
Carlos
Old 11-20-2004, 11:41 AM
914 Geek
Remove the rain tray drip tubes, and work through the holes those used to go through. I believe that's what people have done with some success. They are a real PITA, though.
--DD
Old 11-20-2004, 01:24 PM
Thanks Dave,
I really appreciate your feedback. I might just let a shop do this one, since I'm short on time... but I might feel adventurous and tackle the task tomorrow.
Thanks for your help
Carlos
Old 11-21-2004, 12:10 AM
Like Dave said, if you remove those drain tubes, it gives you a better vantage point from the engine bay. Just be very careful to get a good grip on the top side. It is easy to let that slip and end up twisting the hardline. (Ask me how I know that) Also, make sure you use flare nut wrenches. They are definately worth the investment. They will give you a much better grip, and are much less likely to strip the fittings. Good luck.
Brian
1973 Silver 2.0
Old 11-23-2004, 04:57 PM
