Can a 914 trans be used in a 911
I have a side shift transmission listed on E-Bay.
I got a question asking if this will fit in a 72 911. I have no idea if the 914 transmission will fit in any 911's. I always figured the the gears were in backwards because the engine and trany are in backwards in a 914. Does anyone know the answer to this question? Thanks...................Vern |
RETIRED
Yup...it fits...but will give you five reverse gears unless the ring gear is flipped....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
914 Geek
And you will want to replace some of the shift mechanism that is inside the gearbox. Especially if you start with a side-shift transmission.
IMHO, not worth the hassle. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
In the shop at Pelican
Dave's right.
It's really more work than just finding another 911 box. You'll need to flip the ring gear, get a different rear cover, chasnge the shift mechanism internals and also, I believe the gear ratios were different for the 914 as well.. |
