| Registered Join Date: Jun 2003 Location: Fresno, CA
				Question on POR-15
			I want to paint my front & rear suspension components and I was planning on using POR-15. Can anyone give me some advice on which product works best. When I visited the POR-15 website, I noticed that there are several different products including POR-15 rust preventitive, and also Hardnose Paint. Each of the above products state that there good for chassis painting. I am also planning on painting around the battery tray area. I have some rust but it's not too too bad. However, when I relocated my fuel pump to the front (a couple of years ago), I noticed the the area where the fuel pump was located was fairly rusted. I'm open to all suggestions. Thanks in advance.........Vern Last edited by Tidybuoy; 04-01-2005 at 10:33 AM.. | ||
|  04-01-2005, 08:48 AM |
| Registered |
			I used POR-15 on the driveshafts on my Corvette when I restored it a few years ago.  I bought the standard POR-15 in battleship grey.  It's good stuff, but I found that 2 coats are better than one... if you do it right, you can get a very nice flowed-on finish with a brush. However, if you're taking the suspension pieces off the car, powder coating can't be beat. I did that on the Vette, basically any piece that would fit in the oven got powder coated. I used an Eastwood kit along with an oven that a guy at work gave me for free. And of course, the powder paints come in a wide variety of colors.
				__________________ Ken 1974 Porsche 914 2.0 "Babydoll" | ||
|  04-02-2005, 03:32 AM |
| Banned |
			Hammerite is better than Por 15.
|  04-02-2005, 04:21 AM |
| Registered |
			heres the deal on por-15...if the surface to be painted is rusted...as in brown colored, then por-15 it...if is is still painted...used something else as the por-15 will simply peel away and not adhere to the surface.  This has been my experience.  Hammerite, or other quality paint will be better suited to the task...
				__________________ Scott 1982 911 SC 1962 sunroof bug 1991 WE Vanagon CARAT WRX conversion | ||
|  04-02-2005, 07:57 AM |
| Registered Join Date: Sep 2003 Location: Mentor, OH
			I really dig the 'starter kit' that they sell. Comes with Metal-Ready, Marine Cleen and a 6-oz can of POR15. I think it's like $20 with shipping.
				__________________ Doug Hardman Shaker Hts., OH 1975 - 914-WRX (Under Construction) 2012 - BMW 535i (Daily) | ||
|  04-05-2005, 06:33 PM |
| Registered Join Date: Aug 2004 Location: Roseburg, OR
			I'm going to use Rust Bullet, you're supose to be able to apply right over the rust, I'll probably use Metal Prep first then Rust Bullet.
|  04-05-2005, 08:57 PM |
| Registered Join Date: Mar 2001 Location: Pacific, MO USA
			I used the "kit" Cpt Tripps referred to on my rear swing arms about 3 years ago with great success.  I know someone is going to throw up the "B*ll*****!!" flag here, but after following the directions (bare metal, metal ready, drink a beer, coat with POR-15) and letting them dry for a day, I went to check on my results.  Had them hanging from the workbench by some bailing wire (which incidentally no garage should be without!), and didn't have a good grip on it when I cut the wire.....CRASH!! Right onto the floor..#&^*(%%#!!!!   , actually put a chip in the concrete, but didn't mar the coating at all .......I bought another 6-pack of the little cans, a gallon of metal ready, and proceeded to coat everything metal....and I mean everything.......unfortunately, that again was 3 years ago, and the car is still on all 4's (jackstands that is..) DWD....   Oh yeah, no rust through so far....
				__________________ "Whether you think you can, or think you can't, you're probably right" - Henry Ford '73 914 '75 914 | ||
|  04-05-2005, 11:03 PM |
