Question about Engine Tin
I was wondering what the best practice is - related to engine tin.
I recently removed the engint from the car and as the car was being raised off the dropped engine, some of the engine tin got hung up and bent a little bit.
Now, I have 3 engines and all the tin for each. I was going to take the best from each engine and paint. But, I don't want to screw it all up when the engine goes back in.
Do you guys usually install all of the tin before installing the engine or install it after the engine goes back in.
It seems that installing it while the engine is out is cefinately the easiest, but not necessarily the best way.
Any thoughts?..........................Vern
Old 04-09-2005, 01:10 PM
ruddyboys's Avatar
you have to put the tin on before installing engine, most parts wont go on with engine in.
74 LE "Bumblebee"
03 Jetta Wagon
Old 04-10-2005, 08:16 AM
John Rogers's Avatar
That is true with a four or a six. It is also agood idea to put in the rubber seals first, with the engine out as it gives you a lot more room to work.
Old 04-10-2005, 11:13 AM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
powdercoat the tin instead off painting it as it last far longer and wipes clean,
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 04-10-2005, 12:48 PM
I was thinking about the powder coating option but I have a couple of questions about that:
Does powdercoating stand up to high heat?
Is it usually the norm to completely prep before bringing to the shop (i.e., bead blast). I don't have that type of equipment (yet).
Vern
Old 04-10-2005, 08:51 PM
Any body ever use any of those heat dissipating paints on the cooling tin? Or the block for that matter?
Cuurent fleet:
76 914 2.0 with subtle tweeks ..my grin machine
66 Black Ghia..all original ,including rust
66 Red &White Ghia 2liter 914 engine ..restoring it from a californicated custom soon
90 Maroon and Silver Conversion Van ..the shag mobile..family car/camper
94 saturn wagon ..the wifes pos
Old 04-11-2005, 05:07 AM
Bleyseng's Avatar
The powdercoating shop I have mine done at beadblasts the rusty crap before the coating.
Geoff
www.914Club.com
My Gallery Page
Old 04-11-2005, 07:40 AM
Conrad W Peden's Avatar
How hot is the cure oven for powder coating? 300-400 deg. F?
Should take the heat.
We'll be having an ISO9000 audit soon.
I've divided our preparation tasks into two groups: Unethical and Unproductive.
Old 04-11-2005, 09:34 AM
