Case Splitting Problem
I am having a heck of a time splitting the case on my latest project.
I've done 6 previous type4 rebuilds and never had this sort of challange before. I did the obvious ( go to bed , come back and check one more time that all the fricking bolts are removed).
I've applied heat to seam and gently beat on the bits that can take abuse (like the extra bit of casting at the top rear). I'm guessing that a previous owner sealed this case with permatex.
Are there any solvents to loosen this sort of stuff up? Any other tricks I can try?
Thanks in advance
Bill
Cuurent fleet:
76 914 2.0 with subtle tweeks ..my grin machine
66 Black Ghia..all original ,including rust
66 Red &White Ghia 2liter 914 engine ..restoring it from a californicated custom soon
90 Maroon and Silver Conversion Van ..the shag mobile..family car/camper
94 saturn wagon ..the wifes pos
Old 04-27-2005, 08:17 AM
jamcleod's Avatar
Send a message via AIM to jamcleod
only trick i know of is a "spreader" tool that is put in the oil pump hole to spread the cases. of course, it's only used if all bolts and nuts are removed.....
maybe the tool can be found at a type I site....
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 04-27-2005, 12:06 PM
Acox914's Avatar
Send a message via AIM to Acox914
yes. i picked up one at a bug shop. its used tospread teh case. a few bucks later and no headaches....
-Aaron
"60% of the time, it works every time"
Old 04-27-2005, 12:33 PM
914 Geek
Heh... All I had to do was look at the title of the thread. While it was opening, I said "There's a bolt you have not found!"
I am still thinking that there is one. I know you've checked--and checked and checked. But 9 times out of 10, the reason a Type IV case does not split with only a small amount of effort is that the splitter forgot to remove a bolt.
There is an RTV solvent. I forget what it is, but you may be able to find some at your FLAPS.
--DD
Old 04-27-2005, 12:34 PM
Of course Dave is correct..I missed that damn bolt down twixt the pushrod tubes!
Bill
Cuurent fleet:
Old 04-28-2005, 10:23 AM
ruddyboys's Avatar
How many bolts are there that hold the case together?
74 LE "Bumblebee"
03 Jetta Wagon
Old 04-29-2005, 09:41 AM
norustscott's Avatar
all of them
Scott
1982 911 SC
1962 sunroof bug
1991 WE Vanagon CARAT WRX conversion
Old 04-29-2005, 12:34 PM
