Modifying GT valance continues
I tacked the brake ducts on the other day and today I lowered the opening for the oil cooler. Since I will be using the stock bumper with the GT valance I decided to increase the opening by an inch. It's blocked and it's almost ready to glass up.
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 |
What did you use for those ducts? Looks like something borrowed off of something else, just can't place it.
Also, how are you routing that air to the brakes? Maybe a picture from underneath please! Certainly not using Trekkor's Home Depot PVC pipe right?
Herb '72 Tangerine 'Teen 2.4 liter aluminum handgrenade |
Brake ducts courtesy of an aftermaket Ebay Shelby Mustang side scoops which I butchered of course. I am drilling a hole and ducting the air straight up into the open area under the headlight buckets then out the existing hole seen from the inside of the trunk ( area were stuff always falls into ) then will enter the wheelwell in the appropriate spot via a new hole and then to the rotors.
pic
It will look like this in a few months.
