side output shaft seal
is it easy to replace the side output shaft seal with the transmission in the car. Mine seems to be leaking
Mike Ginter
Yes. It's really easy. Get new seals before you start the job. Don't forget to smear the shaft/seal mating surface with gear oil before installing the seal.
Ginter's 914 stuff |
do not scratch the bore when you pull the old ones... or it will leak. use a ring of same OD to tap the new seal in
-Aaron "60% of the time, it works every time" |
Thanks guys
