BigDBass's Avatar
Send a message via ICQ to BigDBass Send a message via Yahoo to BigDBass
Nasty brake sound on front right
Spent a good chunk of yesterday scrubbing my wheels, taking off the chromed plastic PORSC E off the grill, scrubbing the grill, and installing some nicely polished silver metal PORSCHE letters courtesy of our man Chappy.
Drove over to my mom's today to give her a ride in the 914. Ended up turning around sooner than planned when I heard and felt a crunching/grinding sound coming from the front right wheel. Upon releasing brakes, something still seemed to rub a little bit until moving 2 or 3 feet, then stopped until applying brakes again.
I headed home, and to some degree the crunchy grinding noise/feeling faded substantially, except for the last moments of coming to a complete halt, when it occured briefly.
So, pelicans, where do I start looking?
Dan
1974 914 2.0 in Ravenna Green/Poop Brown
Old 05-14-2006, 08:18 PM
Hey! Nice Rack! "Celette"
rich's Avatar
Check your wheel bearings.
Early Alien Sightings
914-M28/11 5.0 Hybrid (The Alien Sharkster)
I think I smell your blood in the water
WCC 04 done by the kids
Who says Aliens only abduct people.
Old 05-14-2006, 08:39 PM
broken pad material? it's happened.
Old 05-14-2006, 08:43 PM
M. Hendrix's Avatar
Sticking too!
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 05-14-2006, 09:09 PM
So.Cal.914's Avatar
Sounds like text book brake failure. before the roter is mangled
I would sudjest you remove the wheel and confirm this. Replace
pads on both sides.
Old 05-14-2006, 09:15 PM
Headrage's Avatar
Had the same thing happen to mine on a fun-run last year.
Left rear outside pad came apart.
Old 05-15-2006, 06:17 AM
BigDBass's Avatar
Thanks all.
I'll take a look after work today.
Any particular front pads I should be looking for for street use? Can I get 'em at FLAPS?
Dan
Old 05-15-2006, 07:04 AM
JW Apostate
trekkor's Avatar
I'm going to say if the brakes still feel right, you have a pebble/small stone stuck between the dust shield and the rotor.
It's happened to me many times. Usually clears itself. The last one did not, so I had to tug on the edge of the dust shield while turning the wheel until it fell out.
It was the worst brake noise I've ever heard.
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 05-15-2006, 07:58 AM
914 Geek
Most FLAPS won't have good brake pads for our cars. At least, not judging by my experience quite a few years ago. The regular stock-type pads are fine for normal street use. I personally don't have a preference between Jurid and Pagid, though I've never tried Textar or Mintex.
http://www.pelicanparts.com/catalog/shopcart/9144/POR_9144_BRKpad_pg1.htm#item2
I now have the (once PBR, then Axxis, now ???) Metal Master pads on my car, and feel that they are quite good for street use. It takes a good bit of effort to get them to grab, but they will haul the car down from speed if you lay on the pedal enough. (I'm thinking of "downgrading" to a 17mm MC to get less pedal effort.)
http://www.pelicanparts.com/catalog/shopcart/9144/POR_9144_UP9144_pg5.htm#item32
Porterfield's R4S (I think it was) pads--their "street" pads--are really great at scrubbing off the speed. I am told they will wear rotors somewhat quickly unless they get hot, where they really "like" to work, and they can squeal and that they do make dust. But they hold up to high temps very well, and they really work. They are more of an autoX and/or light track day type pad, it seems to me. I know people who use them on the street and like them, though.
Most "racing pads" are not suitable for street use, because they have to get hot to have much grip at all. Hotter than you would see in anything like normal street driving--and having brakes with no grip is not a good thing, as you can imagine.
--DD
Old 05-15-2006, 09:08 AM
Acox914's Avatar
Send a message via AIM to Acox914
I vote the porterfield R4S. great street/AX pad.
-Aaron
"60% of the time, it works every time"
Old 05-15-2006, 09:11 AM
KT
I agree with Trekkor. I have had it happen a few times while AXing & driving. Usually backing up seems to help remove the stuck rock. Pull the wheel and look between the dust shield & rotor.
Garold Shaffer
1973 914 2.7 /4 Flared Beast - SOLD
74 2.0 Daily Driver
74 LE Bumble Bee Project car
Old 05-15-2006, 09:35 AM
BigDBass's Avatar
Man, I hope Trekkor and Garold have the right diagnosis. I was hoping to show off the ride at our baby shower this Saturday, but there's no way I can get the parts and do my first brake work by then. I can definately feel whatever it is in my foot through the pedal. 5.5 hours 'til jackstand time.
Dan
Old 05-15-2006, 09:40 AM
PMB Performance
Eric_Shea's Avatar
I'm with Rich... how far was it to Mom's house?
Eric Shea - PMB Performance
855-STOP-101
We Restore Vintage Calipers
www.pmbperformance.com
Old 05-15-2006, 10:10 AM
BigDBass's Avatar
Probably put on about 5 miles during/after the ugliness.
Dan
Old 05-15-2006, 10:18 AM
BigDBass's Avatar
Clayton found a very little bit of play in the front left wheel bearings. He didn't seem too concerned, but that it was there. I don't recall the front right having been checked.
Dan
Old 05-15-2006, 10:20 AM
PMB Performance
Eric_Shea's Avatar
At this point the bearing play can be deceiving. I had one go just like what you're describing (at the 98 historics). I too thought it was a rock behind the shield (camping at the track) because I checked for bearing play and there was none. Once the bearing goes, all hell breaks loose in there and it can actually tighten up and bind on the outer race (my guess as to what you're hearing).
Bearings or brake pad. If you can feel it through the pedal it may be a pad. It could be a broken pad spring wedged in there as well...
855-STOP-101
Old 05-15-2006, 10:41 AM
BigDBass's Avatar
stuff wasn't supposed to start breaking this soon.
Dan
Old 05-15-2006, 10:56 AM
So.Cal.914's Avatar
You could have a cheap set of pads on one side in an hour. I repeat
cheap pads(Pepboys). After the shower you can put in a good set on both sides and turn the rotors.
Let us know what you find.
Old 05-15-2006, 11:12 AM
auggie91420's Avatar
Dan,
Keep us posted. If the brakes check out and it is the bearing, I have a set, as well as all the other stuff you need. Easy job with the right tools. Another excuse for a ride on Saturday. BTW, you're right, we didn't check the other wheel.
Old 05-15-2006, 06:23 PM
On a 4-cylinder 914 the bearings mount in the rotor. If you find that you need new bearings, it might be a good time to change out your front rotors if they have a lot of mileage.
Old 05-16-2006, 06:16 AM
