bowlsby's Avatar
What is 'It' that you tried and didn't work Jared?
Did you try the 1.7L injectors on a 73-74 2.0L engine and they were lean (as would be expected) or did you try the 75-76 2.0L injectors on a 73-74 2.0L engine, and they were lean?
Old 07-29-2006, 08:16 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
1.7 injectors on a 2.0
Old 07-29-2006, 01:05 PM
Just how much hotter would the engine run with 1.7 injectors installed? Anyone have data?
Old 07-30-2006, 08:20 AM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
On a 1911 motor I was getting A/F ratios of 16to1 at WOT which is way too lean.
I could get the partload setup for about 13.7to1 but it would go pretty crazy and not be a stable A/F ratio. Meaning with any throttle it would go lean and then try to settle back down.
I was in a hurry setting up this car for a friend so I didn't do too much testing. I swapped in a set of 2.0l injectors and tuned it quickly.
I would imagine that you would cook the heads if you kept the setup as 16to1 way too lean. This was with me adjusting the MPS as much as I possibly could.
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 07-30-2006, 05:00 PM
