op3 op3 is offline
Engine Rebuild Lubes
Hi All..
I am about to rebuild (or build) my T.4 for the first time.. Its and EC block w/ 2.0 heads and jugs, fuel via 44mm Webers and a Webcam to give it a little more ummph.. Webcam sent me some cam lube for the cam, but i'd like to pole you all on what other lubes, greases or sealants are recommended for the sealing case, heads, bearings, yada, yada...
Any and all help/advice greatly appreciated..
Chris
Old 06-01-2001, 08:10 AM
paulhagedorn's Avatar
Send a message via ICQ to paulhagedorn
Post
Stuff I used was white grease, lithium grease, some kind of really thick red oil that I think was called engine assembly lube...go to NAPA or Auto Zone and ask the guy behind the counter...generally they can point you in the right direction.
Paul
Old 06-01-2001, 08:39 AM
914 Geek
Porsche Crest
There are specific engine assembly lubes. Use them. Some are red, some are black, some may even be purple for all I know...
As for case seam sealers, I've heard very good things about Hondabond and Yamabond, two sealants made for air-cooled motorcycles. Bruce Anderson recommends some specific Dow-Corning product in his 911 book. And there are other products that should work too, but I don't recall what they are offhand.
--DD
Old 06-01-2001, 12:31 PM
Post
YAMABOND IS GOOD STUF
Old 06-01-2001, 12:52 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Post
Curil K2 Steve
Old 06-01-2001, 06:32 PM
Post
I recommend using 20wt engine oil, mixed with a tad bit of STP oil treatment..I do not use the assembly lubes, they give an artificial feel to the engine during assembly, and may cause some problems when checking tolerances...
I seal every case I build with Curil k2, and a little something from the medicine cabinet.......take a guess at what it is
Old 06-01-2001, 07:30 PM
Post
Vaseline?
Old 06-01-2001, 08:24 PM
Post
Nope, it is not a lubricant, is a sealant...I place it between the case halves, all the way around...Give up, you will never guess it...LOL LOL>
Old 06-01-2001, 10:40 PM
chibone_914's Avatar
Wink
jake, Please don't say it's Dentucreme. Thats a sealant/adhesive, I guess.
It's either that or Preparation H.
Personally I like the feel of STP and 30wt Castrol for the assembly.
As for the case halves, I agree with most aircooled afficionados....Curil K2.
Have an Awesome Weekend All!
John
72'914
Old 06-01-2001, 10:48 PM
op3 op3 is offline
Post
Thanks for all the input guys...
I think i am going to opt for the Castrol straight 30w and the STP..
As for Seam sealer, I've been advised that the current stock VW orange goo (supposedly same as MB and Porsche factory sealer) is the way to go.. #AMV 188 200 03..
now.. for engine break-in, straight Castrol 30 or Kendall 20w-50? and milage? 1k?
[This message has been edited by op3 (edited 06-03-2001).]
Old 06-03-2001, 06:06 PM
Post
USe Kendall 20 W 50, for break in..The cam will love you for it..
Old 06-03-2001, 06:20 PM
op3 op3 is offline
Post
Thanks Jake...
guess that'll be the plan... so do tell us what is that other stuff you use to seal the case??
Old 06-04-2001, 10:47 AM
djs djs is offline
Post
Since nobody asked me...
Having ruled out both toothpaste and roll-on deodorant for sealing the case halves, I'm thinking Jake uses dental floss for this purpose. Embedded in the Curil, it would compress and act as a physical barrier.
But I could be wrong.
Old 06-06-2001, 07:18 PM
DDS DDS is offline
Post
Clear nailpolish? Dentucream? If not that, just what the heck do you have in your medicine cabinet Jake? Stop laughing.
Dave
Old 06-06-2001, 08:31 PM
Post
Just make sure it is waxed!!!
It works great, good guess DJS.. Thats my secret, keep it to yourselves..
Before anyone says that it affects case torque, or crush factors, it is less than .001 thick when compressed, curil alone is .001 and many sealants are twice that thick..
I have used it with no sealant, at all, and it worked like a champ..
Old 06-06-2001, 11:16 PM
