The previous owner of my 75 chassis had the rear rotors and hubs drilled to the 911 5 lug pattern. I haven't removed the rotors to get a better look but it appears where they were redrilled they are also threaded? So they take a lug "stud" rather than a lug "nut". I believe a better way to do this is to have the hubs modified and have studs installed but when you do that what rotor do you use? I don't like the idea of every time new rotors are needed I have to visit a machine shop to get them drilled. Does the 914-6 rear rotors just bolt on? Are the readily available? Is there another rotor that will bolt on? Thanks guys I'm learning
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
914 Geek
914-6 rear rotors are available, and they do bolt on. Some people have had problems were the outside edge interferes with the "bridge" where the caliper goes around the rotor, others have not. The interference, when present, is very small. You may be able to avoid it simply by pushing the caliper outward when tightening the bolts, or you may have to do a little modification (grinding, maybe sanding) to the outside edge of the rotor.
Some have ground the inside of the bridge, but you have to be very very careful--one of the fluid passages is not so far under the surface there... --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
