TURN SIGNAL RELAY location
Can anyone tell me where the turn signal/emergency flasher relay is located? I brought down the relay board but I couldn't identify it . thanks
Old 06-03-2007, 10:09 PM
914 Geek
It's the square one that sits up on top of the fuse panel. The fuse panel is the thing your toes keep knocking the cover off of when you get out of the car... It's held on by two screws, and you can drop it down to get at the top just by removing the screws.
--DD
Old 06-04-2007, 07:24 AM
Thanks Dave
I did see that however it looks different than the replacement . The replacement is longer than the one that's there. I'll have to look at wiring schematic to make sure I plug it in right .
Old 06-04-2007, 12:18 PM
thanks dave found it. It was tucked away. What I was seeing was the headlamp relay. Thanks again.
Old 06-04-2007, 08:34 PM
