Removing the speedometer
Ok...I've decided to look into the odometer problem. I have the speedometer loose in the dash hole but it wont come out. How do I get it unhooked from the cable that runs down to the trip reset knob.? Is that what's holding it in there???
Roger
'74 914-2.0
Old 07-13-2007, 04:09 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
The reset cable is simply pressed into the back of the speedo; there is a plastic barb that gets wider after it pushes through the hole. You should just be able to pull it out, I think.
Or you could take the knob off the bottom, then remove the nut that holds the cable onto the underside of the dash.
--DD
Old 07-13-2007, 05:56 PM
