Post Fuel pump problems
Have the rebuild and engine back into car, re-installed all the FI the PO had removed and fortunately saved in a box for me. Turn the key and no fuel pump, if you crank the starter then you get the 12v to the pump connection. From previous posts I thought the fuel pump was to run ~1.5 seconds. I didn't get a chance to trouble shoot very long. Maybe someone could point me to a starting point. It is the 1.8 with L-Jet.
Thanks,
Brian
'74 1.8L in resto
Old 08-19-2001, 09:10 PM
Post
well first on the 1.8 the feul pump does not run for the 1.5 second, it runs when the starter is cranking
check the double relay one is the main relay the other is feed from the air flow sensor pump contact
you can pull the cover off of it and push the relay by hand, with the cover off the one you want is the left one as you look at the relay side ( as opposed to the circuit board side )
if that does it then the problem is betwwen the air flow pump contact and the relay
check the big red wire from the relay pack to the battery ( about 8 or 10 guage )
while you are in the relay chech that the contact is good mine burnt off and i hard to solder it back on
also the relay on the reg board does nothing on a afc fi system but it can be jumped out to make it run
if you still need more help email me
scott thacher
75 1.8 on the road again
75 under rust
(fine german rust)
Old 08-19-2001, 09:32 PM
914 Geek
Porsche Crest
You need three things for the engine to run:
1) Air (or compression)
2) Fuel
3) Spark
If you have all of these, then the rest is a question of how much fuel, and a question of timing.
Check for the basic three things. Do a compression check. Check for spark--a spare spark plug, taped to a ground, should give you a visible spark when the engine is cranked. Make sure fuel is going in. You can pull a fuel injector and put it into a jar (disconnect the coil if you do this, to avoid sparks!!) and look to make sure it squirts fuel.
After that, you should check the static timing and then start checking FI components.
--DD
Old 08-20-2001, 09:42 AM
Post
OK, looks like the fuel pump is no good, turns very slow and +12v at the fuel pump connection. Looking for a pump now.
Thanks,
Brian
'74 1.8L in resto
Old 08-20-2001, 05:18 PM
