HELP ASAP.........Replacing Dashboard
FIRST TIME DASH REPLACER:
Can the dash be replaced without removing the windshield?
YES, NO?
ELABORATE PLEASE; I'LL PAY PER WORD lol
Old 02-06-2008, 01:08 PM
Control Group
Tobra's Avatar
Pretty sure you can. It is the seal at the base of the windshield that you can't do with the windshield in.
Half a sec
check it
http://www.914world.com/bbs2/index.php?showtopic=42757
Last edited by Tobra; 02-06-2008 at 02:38 PM.. Reason: found the very thing you are seeking
Old 02-06-2008, 02:31 PM
SirAndy's Avatar
if the windshield is installed correctly, you can replace that seal without having to remove the windshield.
the mounting lip is in a small recess allowing the seal to slide in/out without pressure from the windshield.
as for the original question, yes, the dash and even the metal subframe can be removed with the windshield in the car.
however, having the windshield out makes the process a lot easier ...
Andy
>> 1970, 914-6, 3.6L (Conversion)
>> 1970, 914-6, #374 (Original)
>> 1975/73, 914 Limo (Custom)
Old 02-06-2008, 06:52 PM
speedemon666's Avatar
Where can a person order the dash to windshield seal?
Old 02-08-2008, 08:58 PM
Auto Atlanta has both the orig and a reprod. (which is a lot cheaper and fits fine).
The hardest part about the dash removal is the 4 bolts that come through the front crosswall that are all but impossible to do without the gas tank and entire fresh air blower system removed.
Bren
Old 02-15-2008, 08:15 PM
