HELP ASAP.........Replacing Dashboard
FIRST TIME DASH REPLACER:Can the dash be replaced without removing the windshield? YES, NO? ELABORATE PLEASE; I'LL PAY PER WORD lol
Control Group
Pretty sure you can. It is the seal at the base of the windshield that you can't do with the windshield in.
Half a sec check it http://www.914world.com/bbs2/index.php?showtopic=42757
She was the kindest person I ever met Last edited by Tobra; 02-06-2008 at 02:38 PM.. Reason: found the very thing you are seeking |
the mounting lip is in a small recess allowing the seal to slide in/out without pressure from the windshield. as for the original question, yes, the dash and even the metal subframe can be removed with the windshield in the car. however, having the windshield out makes the process a lot easier ... Andy
>> 1970, 914-6, 3.6L (Conversion) >> 1970, 914-6, #374 (Original) >> 1975/73, 914 Limo (Custom) |
Where can a person order the dash to windshield seal?
Auto Atlanta has both the orig and a reprod. (which is a lot cheaper and fits fine).
The hardest part about the dash removal is the 4 bolts that come through the front crosswall that are all but impossible to do without the gas tank and entire fresh air blower system removed. Bren |
