Question Lighting Problem
Three out of the four parking lights are on with the ignition on !. Lights/ switch work normally, but with the ignition on or car running 3 of the lights are on.(full bright, not partial like a weak ground would give) I've replaced headlight switch,cleaned contacts and grounds, pulled the steering column and checked connections, still stumped. Any advice would be appreciated. Its a 1970, Thanks.
Old 10-14-2001, 06:00 AM
Jim Smolka's Avatar
Post
I assume that you do not have the light switch on and 3 lights are burning (which one is not). Could be a problem in the turn signal switch.
I assume you are using a Haynes manual as a reference???
The earlier electrical drawings are not so good, but the later years are and they are very similar to the '70 wiring.
Old 10-14-2001, 11:42 AM
914 Geek
Porsche Crest
Don't assume that a bad ground would cause the lights to be "weak"... This sounds a lot like a bad ground or wires mis-connected to me...
Did it start doing this all at once? If so, what happened to the car just before? Bodywork? (I hate body shops--I have yet to find one that I think is fully competent.) Replaced a bulb? Took out a taillight to clean it up? Other?
--DD
Old 10-15-2001, 09:19 AM
