Help Frustrated
I just started my 1.7 after an extensive rebuild including valves, valve guides, gaskets,bearings rings. I started the car today and it is leaking oil from the exhaust. I only let it run for about ten seconds. Any thoughts
Old 09-03-2008, 05:42 PM
jhora's Avatar
out of the tail pipe......how bad was it "leaking"....was it like poring out??
maybe some residual oil left in the headers and muffler
Old 09-03-2008, 06:21 PM
I thought that at first since it was black at first. But it was spraying out, hitting the wall six feet away in a nice spray pattern.
Old 09-03-2008, 06:30 PM
yes out of the tailpipe
jhora's Avatar
sorry to hear that...pull the plugs and see if one is coated with oil
Old 09-03-2008, 06:40 PM
If it is, what will that indicate?
Old 09-03-2008, 06:42 PM
Thanks for the responses, I have to go for now. One other bit of info, I never checked the pressure relief valve and I started the engine with most of the vacuum tubes not connected as I just wanted to see if it would start
Old 09-03-2008, 06:47 PM
jhora's Avatar
to see if one of the cyl is passing oil or all of them..
FI or carbs.....
Old 09-03-2008, 07:03 PM
Does any one have a link or digram on how to install the tenions bars for the engine lid?
Old 09-20-2008, 06:13 AM
