Recovering dismantler
neil30076's Avatar
Question Head stud nuts stuck - how to remove?
Pulled both heads on my 1.7, on one the head studs came out with the nut, and no way will it come loose. I have soaked in PB blaster for over a day ( head upside down and nut/stud in a jar of PB).
What is the prefered way to get the *** nut off?
Heat? Cut the nut off part way with a dremel and split? or what?
Any advice appreciated...
TIA
neil
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 03-21-2009, 05:52 PM
914 Geek
Heat is a very good thing to try. You'll need to set up the stud in a soft-jawed vise to keep it from turning, of course. Some tapping on the nut can help penetrating oil soak in, but heat is probably the way to go.
--DD
Old 03-22-2009, 12:18 PM
neil30076's Avatar
Heat was good, thanks Dave.
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 03-23-2009, 03:06 PM
