Door handle
Where can I get the plastic part on the exterior door handle?
Also my high beam indicator quit working. The lights still work high and low. How do you replace the light in the tack?
thanks Glen
Old 03-07-2010, 05:24 PM
Rrrockhound's Avatar
The door handle part is here:
Pelican Parts - Product Information: PEL-DR-CM1
The indicator bulb is in the back of the tach. To get to it, just pull the tach out the front of the dashboard (towards the driver's seat). It's held in place by a rubber ring, so it might take a little twisting. It might help to remove the steering wheel first.
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 03-07-2010, 06:06 PM
The bulb holder does not want to come out. White wire with blue stripe?
Old 03-08-2010, 06:28 AM
You probably will have to turn the holder in the socket with pliers & then pull it out. Don't pull on the wire, tho.
Old 03-08-2010, 03:20 PM
Thanks that kind-a figgured that.
Old 03-08-2010, 04:43 PM
racer's Avatar
When removing the door handle to replace the broken plastic piece, try not to drop the securing bolt. I dropped mine.. then couldn't find it in the various cavities in the door. So I bought a replacement.. shut the door and heard the old bolt fall out loose to the bottom of the door
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 03-08-2010, 05:32 PM
Yes I was very careful about the screw.
Thanks Glen
Old 03-08-2010, 05:53 PM
How to
Any tricks for installing the Plastic door latch cams? how do hyou get them in the little holes on the arms? what kind of lube do you use?
Old 03-11-2010, 07:19 AM
914 Geek
You lift the flap as if you were opening the door. The arms have just enough play in them to get them over the knobs on the arms of the cam. It can take a little wiggling, but don't force anything! The metal parts are not that strong...
--DD
Old 03-11-2010, 09:52 AM
Thanks for the Tip!
another question
The High beam light works but the blue lense is not very bright when lit. Almost cant see it unless the insturment lights ard dimmed and it is dark????
Old 03-11-2010, 05:22 PM
