windshield wiper switch replacement
What is the procedure for removing and replacing a Porsche 914 windshield wiper switch assembly? Thanks
Pull horn pad ... pull steering wheel ... remove 4 screws ... disconnect electrical plugs from back of switch ... pull assembly out and watch for dropping parts (ground tabs). You will also probably lose the washer hoses as they don't like to come loose and break off. That's about it. Assemble in reverse. Getting the electrical connectors back on can be painful. Laying on your back with the driver's seat removed helps a bit.
Ron Meier Backyard Shadetree Mechanic 1974 914/6 conversion with 2.7L (The Grey Ghost) 1973 Chalon with 2.4T MFI (Schlitzalom) All my 4 cylinders are gone
