slipping clutch wit 3.0L motor and 901 gearbox
Hi,
after modifying my 914 to a 914-6 with a 3.0 SC (K-JET) motor my clutch starts to slip after only 2000 km driving. I am using the original gearbox from the 914 (the so-called 901 type). Therefore I have cut off the ring gear from the flywheel of the 4-cylinder motor and bolted it onto the flywheel of the 3.0. No drilling was needed in the 3.0 flywheel. I also used the old pressure plate that belongs to the 901 gearbox, as it stilll looked in good shape. However, I renewed the clutch. I suspect the surface of this clutch and pressure from the pressure plate is insufficient for the (180 HP) 3.0L motor. My question is if the Sachs SPORTS pressure plate (#88-3082-999-741-M410 from Pelicanparts) will be strong enough. Though this is quite an expensive pressure plate, it is still cheaper and lighter than converting a 915 gearbox. Does anybody have a suggestion or specs of this pressure plate? Eventually, the original Sachs number is welcome as well. Thanks very much, Gerber van der Graaf |
Maybe you are not getting enough clamping force as a result of your modifcation. There is a max distance from the pressure plate mounting surface to the flywheel friction surface.
Off the top of my head I can't remember what it is. It's in the factory manual however. If you need another sachs clutch disc I have a brand new one I won't be using. PM for a REALLY good price. |
I went with a Stage-II clutch and pressure-plate package from KEP for my conversion. (See link below) Porsche Pressure Plates You'll need something that can handle the torque ... Andy
>> 1970, 914-6, 3.6L (Conversion) >> 1970, 914-6, #374 (Original) >> 1975/73, 914 Limo (Custom) |
Thanks Andy, this might be a good solution. Gerber
I also am using the KEP Stage II pressure plate and clutch disc with my 3.0 works fine. I think it's good for up to 275 ft. lbs. of torque but has a very easy clutch pedal feel.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
canna change law physics
I used the SACHS clutch with my 914-6 after the HP upgrades. It was well over 200 HP and worked fine.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
| Tags |
| 3.0 6-cyl motor , 901 gearbox , 914 , clutch , pressure plate |
