retrogarage's Avatar
Delphi Green L99A
Just bought 74 914 w/ 12K. It is original paint except one door. It doesn't match well. Delphi green is over 50% clear. It is going to spray out very translucent. I need to know what base color or primer was used at the factory so I can get this absurd color to match better?
Was original paint acrylic enamel?
1977 911S Targa 1967 Double Cab
(2) 1962 23 window 1958 Single Cab 1964 Ruby Red Kombi
1964 Flipseat Westy
Old 08-05-2010, 08:59 AM
Delphi Green
Thought it was a 12K car but turns out 18K documented miles. Always stored inside.
Here are some pics. Need to match this crazy paint on a few spots.
1964 Flipseat Westy
Old 08-16-2010, 08:19 PM
BURN-BROS's Avatar
LOL, even the dog is afraid of that color!
find a spot you can remove a little paint to observe the primer. Delphi or Ravenna Green both look great as widebody cars.Nice find!
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 08-17-2010, 07:29 AM
racer's Avatar
Sure is dusty, but if only 12K miles (not 112K), thats a real nice find. Any idea why the door paint wasn't matching to begin with? is it a 1.8 or a 2.0?
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 08-17-2010, 01:55 PM
It has 18K. Yes it is documented. I got from original owner. Never touched since 83.
Bicycle fell on door and rear tire wobbled the fender . Only thing that will be done is paint match the couple of areas.
Leading to my question:
What color primer or base is under L99A Delphi Green. The paint is over 60% clear.
1964 Flipseat Westy
Old 08-17-2010, 08:39 PM
Pete000's Avatar
Nice find !
Whats that hanging under the dash ?
Work to Live, don't live to work...
Old 08-23-2010, 02:06 PM
8 Track tape player. Had Jim Croce in there but PO wanted it bsck.
1964 Flipseat Westy
Old 08-24-2010, 06:07 AM
Okay I think I have this Delphi green paint figured out.
I found a paint code sticker in door jamb that says(pics soon):
TWO STAGE PAINT
L13M SATURN YELLOW
The build plate on car says L99A Delphi Green.
While cleaning I found a chip in the paint revealing a yellow base or primer.
With this info I am certain that the base color is SATURN YELLOW under the very transparent DELPHI GREEN.
So I shot a test piece and the Saturn Yellow is a flat base that matched the chip on car perfectly. The Delphi Green is very tough to match. I need less green and more gold on the next test shot.
1964 Flipseat Westy
Old 09-19-2010, 08:17 AM
