Griffinroydonal's Avatar
Tool Kit Question
I found some tools in a box in the parts car and wanted to know if this is what came with the car from the factory or if it was something the dealer added when sold.
Wrenches are marked - Selected-Special-Steel - West Germany, and are 12/13mm -
14/15mm - 17/19mm.
The Pliers are marked - Hapewe - Germany.
The lug wrench is marked - Klein -17 x 19-Made in West Germany.
I thought about making up a tool kit for the car with the stuff I found but wanted to know if it is correct.
Warning - I play with Porsche's
1970 -914 / 1982 -911
1984 -928 / 1987 -928
Old 03-22-2011, 01:30 PM
914 Geek
I think those are aftermarket. I believe that the stock lug wrench was just an open-hex-shaped thing that you put a bar through to turn. The wrenches look similar to what I thought the stock ones are, but I had thought that ours were made by Hazet.
I am not absolutely certain, though. Have you looked in the Brett Johnson "Guide to Authenticity"?
--DD
Old 03-22-2011, 03:23 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
You still need a spark plug socket, wheel lug nut socket and screwdriver. Also look for a hub cap/wheel cover puller and tool bag. I think the wrench was double open ended 10mm and 13mm.
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 03-22-2011, 04:41 PM
Wheel lug nut socket
Old 03-22-2011, 05:09 PM
Control Group
Tobra's Avatar
the tool kit that came with the 914 was very similar to the one that came with a Super Beetle, had the lug/spark plug wrench, the screwdriver, which was reversible, 10/13 open ended wrench, tommy bar for lug wrench, even the jack, all stamped "Made in West Germany"
Old 03-22-2011, 08:59 PM
jamcleod's Avatar
Could be other cars that have this wheel lug socket but it is a 944 socket, still usuable on 914; better in fact than stock one.
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 03-23-2011, 02:39 PM
I pulled the tool kit from my 1987 - 928s4 today and the wrenches are marked the same " Selected-Special-Steel " - " West Germany " But are in different sizes. It looks like tools are mix and match for the most part .These are original to the car and had not been out of tool holder.
Old 03-23-2011, 03:31 PM
esses62's Avatar
looks like a BMW tool kit I had from the 80's
Scott
88 911 G50 3.2 Targa Signal Red DP935 NA
95 993 C2 Coupe Black/Black
99 996 C2 Silver/Blue
77 911S GP White/Cork
Old 04-09-2011, 07:25 PM
Control Group
Tobra's Avatar
pretty much the same tool kit they put in Superbeetles. If you want a cheap 914 tool kit that is the way to go if you ask me
Old 04-12-2011, 10:13 PM
