Rear lens gasket??
Are there gaskets or seal available for the rear lens?? If not, any suggestions on what to use.
BMW CCA DE at Portland International Raceway this Friday. Still plenty of time to devolop the 24 hour flu so you can attend. Suppose to be sunny and 60º.
74 914 2.0 (sold) 96 328is |
I believe those gaskets are NLA.
I used screen door spline rubber (that strip of rubber that runs around the edge of a window screen and holds the screen to the frame.) It has the right amount of pliability and a spot of latex or 'Goop' where the 2 ends join completes the install. No more leaks!
Herb '72 Tangerine 'Teen 2.4 liter aluminum handgrenade |
I made the mistake of squirting clear RTV into the groove and put the lens in immediatly. I didn't think about the RTV being a glue. I may still be able to get them apart. I tried running a razor blade around the outside but they still held tight. Anyone got any ideas on what I should do next, besides buying some new lenses and housings?
Tom Las Vegas, NV '74 914.0L Last edited by TomInVegas; 03-27-2002 at 10:18 PM.. |
We use gorilla snot/dum dum. It is available at any hardware store. It comes in a roll, is black, never gets hard, is easily removeable and has many applications. It is made by 3M and I don't know how to describe it. We seal front windshields and rear glass with it. I will get the description/part number later and will post it. My crew got invited to Le Mans this year to crew for Kevin Buckler in the #66 Porsche, I wonder if they need a little help. OTTO
Racing Porsche for over 30 years. http://www.OttosVenice.com Check out the Porsche Owners Club Track event Videos |
914 Geek
That stuff is called "butyl tape". AKA "the stuff that holds the windshield in".
The body shop that worked on my 914 decided to super glue the lenses to the housings. And the housings still leaked, so they used some kind of black gunk all around the housing-to-body seam inside the trunk. I'm not sure I'll ever be able to get those things out!! Hopefully I'll never pop a light bulb... Yeah, right! --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Oh, yeah, super glue is know to be a great sealant. Not! So, Dave, how were there body working skills?
For rear glass sealant I've also used a material very similar to plumber's putty. A little more sensitive than butyl tape, as fas as installation, but a whole lot easier to clean up if you ever have to remove the lens to replace a bulb. The butyl can turn into an amazing black sticky, stringy mess when you try to seperate it.
Mark B '73 911S (long term ownership) '70 914-6 (long term project) '74 914-2.0 (sold) |
