Speed Metal Army General
Originally Posted by strudelwagon View Post
Speed, I know this sounds stupid but have you tried swapping out the MPS. I had a hell of a time with mine with running rich and next to no idle. It was fine when I took it all apart but for some reason it went bad. as soon as I plugged in another MPS, the idle smoothed right out.
Not saying it's you answer but a pretty easy check with 1-plug and 1-hose. You don't even have to bolt it in. Even a good 1.7 one will make it idle.
Tried it!Same symptoms.
Old 04-30-2012, 03:16 PM
Originally Posted by john rogers View Post
In fiddling with the injectors it is possible that one or more has come lose and either the large and/or small donut seal is leaking badly. I would suggest pulling each, do a capacity AND spray pattern test and at the same time see if the seals are okay I.E. soft and pliable and also that each injector has the plastic cap on the end.
I actually put 2 new injectors in w. new seals after this nuttiness started.Im gonna take a vid and post it up...
Old 04-30-2012, 03:17 PM
Some progress...
So...Upon further investigation...The cold start valve was unplugged.It looked like gallons of fuel in the box.Yuck...Anyways,It sounds a bit better after I ran it a bit and blew all that crap outta there.Its running at 29 lbs,so the reg I put on is working.Thats good.
Its becoming clearer..lol..The old reg was CRAnKED to 45 lbs,then while I was digging around down there,I must have knocked the wire off the cold start valve.I started it,saw the super high pressure and let it run while adjusting the reg.Fuel must have been dumping in the box through the valve.Now that the lead is plugged back in,the fuel pressure stays up,instead of dropping to zero over 5 seconds or so.
So,now it runs a tad smoother,still pretty chuggy at low rpms..The car ran well(rich,but well) At 40+ lbs of fuel pressure before.So,is it possible some damage was done?It doesnt want to idle smoothly at all now.Also,now that this thing runs at the proper pressure now,what is my first step to making it right?I fiddled with the ecu know,and the air screw on the TB,small improvement.Turned the dist a shade CCW,small improvement.
More advice please.
Juicy stuff in box.Black,gassy,nasty.Why soo black and crappy looking?
The culprit?
The stuff in the box
The stuff out of my pipes.
Steady Pressure
Old 04-30-2012, 08:00 PM
Betcha can't have just 1
strudelwagon's Avatar
Good find T,
I'm amazed how flaky the injector connectors are on these cars. No real posirive "click" like the newer Bosch plugs.
Hey, where did you buy the gauge?
SW
Old 04-30-2012, 08:19 PM
Good find T,
SW
All those connectors are flaky!And which way do they plug in?Which side is up?lolHey dig my reflection inside the box..
Old 04-30-2012, 08:35 PM
914 Geek
The cold-start valve should only let fuel through when it has a ground on one pin and power on the other pin. When it is unplugged, it should be closed. You might want to re-check that.
I once had the wire to the TTS come adrift on my car; it would often (but not always!) short to the crankcase and the CSV would dump fuel while the starter was cranking. Made for difficult starts.
You might want to check your oil; if it smells like gas change it.
--DD
Old 04-30-2012, 10:43 PM
