how to know its a 2.0 engine
I would like to fine out how to determain the engine code for 2 .0 ,and where its located on the engine.... Thanks Frank
Old 08-05-2012, 10:30 AM
the codes are
1.7 l is W, EA, or EB Located near tranny mounting flange, passenger side on top of engine case.
1.8 l is EC, or AN Simular to 1.7
2.0 l is GA, or GB Located near oil filler, near fan housing on top of case.
Old 08-05-2012, 01:57 PM
John Rogers's Avatar
BUT, many, many engines are no longer what they started life as so the only way would be to measure it to absolutely sure.
Old 08-05-2012, 02:44 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
GC code is also a 2.0 engine. Also in front of the oil filler.
--DD
Old 08-05-2012, 03:27 PM
2.0 engine codes
Is it true that 912e's have no engine codes on the case. I know mine doesn't and I have spoke with others who also advised no engine codes.....
Old 08-07-2012, 04:21 AM
Administrator
IIRC, they have an engine code on the fan shroud. A GC code as well.
--DD
Old 08-07-2012, 08:01 AM
djpateman's Avatar
The more important thing is to see if it has 2.0 heads; the Porsche 914 2.0 heads are the only ones with 3 studs to fasten the intake manifolds to the head. If there is a single stud/nut on the flange between the intake tubes, then it has the Porsche heads. Likely the rest of the engine is 2.0 if the heads are.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 08-07-2012, 09:22 AM
yes, 3 bolt heads
Old 08-08-2012, 02:23 AM
Alright,..!!! Thanks alot guys ...going to look at 1 this weekend...Frank
Old 08-08-2012, 01:08 PM
