SVDA dizzy and non-stock cam
Hi everyone!
I have almost no build details on my motor (GC case 2.0L, Weber 40 IDFs, 009 distributor)
I would like to install a SVDA distributor but I'm worried my cam has probably been changed. My webers have vacuum ports.
I basically know nothing about cams.
Please explain to me what kind of cam would not work (I hear long duration won't work?) and how I would be able to tell it (Torque range? idle?) It seems to have a pretty flat torque curve and the idle is fairly smooth.
Thanks!
Old 06-20-2013, 11:19 PM
you could put a vacuum gauge on the port on the carb. then very slightly open the throttle and see if it pulls any vacuum. in fact, use both carbs, and add a tee. then test the vacuum off of the tee. all your concerned with is from closed to very shallow part throttle.
"D&R GEARBOX"
Porsche and VW gearbox rebuilding.
Brakes, suspension, electrical, tune ups and troubleshooting.
Weber carb rebuilding, jetting and tuning.
4 Wheel alignments with camber and castor adjustments.
Old 06-21-2013, 05:25 PM
Great idea! Thanks for the help!
Old 06-25-2013, 07:27 PM
porschetub's Avatar
jr won't be much chance of the cam being changed,most people don't bother when they convert ,it is obviously a limiting factor in performance as the FI cam is very tame.
So the stock cam will work,just set-up your carbs and dizzy spot on and you will wake up your engine.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 07-20-2013, 08:04 PM
agreed. plus you will get better fuel mileage, and your engine will run cooler too.
"D&R GEARBOX"
Old 07-20-2013, 08:21 PM
