Administrator
Careful, it looks like you may be welding at the location of one of the spot-welds that holds the front bracket for the clutch tube onto the inside of the tunnel. Might even be welding new metal on for the lower spot-weld, in fact.
Just be cognizant of what's going through the area. Make sure not to blow through the tubes any where, and if you have to weld on any of them put some sort of heat sink inside so you don't have weld protruding into the tube. That can make it impossible to get a cable in or out. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Certified Porsche addict
OBTW - Thanks for keeping an eye on my work. I appreciate comments and tips as these are all new skills and techniques for me.
Tennessee Region SCCA & PCA Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend) Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11 Last edited by The Glademister; 12-14-2013 at 05:14 PM.. |
The light at the end of the tunnel.
I started the morning off with marine clean and then rust kill. Having sheet plastic down kept the mess factor low. Then I sprayed the underside and driver side of the tunnel with weld through primer. I'm not priming the whole tunnel because I'll cover it with POR 15. The first long segment was drilled for spot welds every 1 1/2". I clamped that on and started with my first series of rosette welds. That went quite nicely so I followed up with 1" seam welds every 3 or 4 inches. I then fabricated the last segment and had it welded in pronto. Followed up with wire brushing and grinding welds. The grinding process goes SO much quicker with the spot welds. Although the net result doesn't look as original as the butt welded patches I used on the passenger side - I think this side is much stronger.
The last photo shows what I'm dealing with next. There's A LOT of sheet metal missing in the drivers foot well. That area is going to require some complex fabricating and extensive patching. Anyone following this thread that can post a photo showing that area without the peddle assemble in place, just the original sheet metal - that would be most helpful. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Tennessee Region SCCA & PCA Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend) Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11 |
Footwell from hell
So I'm diving in to this last area of floor pan attaching sheet metal. There's not much left here to help me fabricate replacement. I'm starting with the backside of the wheel house and using the passenger side as a template (they appear to be mirror image). There's a sliver of the folded seam from the factory where the wheel house joined the floor pan. Reproducing that exactly far exceeds my skills at this time so I'm just using right angle flanges. I've left those a bit longer than the usual 1/2" so I've got extra metal to work with when it comes time to put the pans on. The bend in the wheel house is a little complex, almost an S curve but it fabs up pretty well. What is handy is being able to weld both sides. This should add strength in a high stress area. Next I'll tackle the front metal behind the peddles and tunnel. I haven't look really close but I think this can be done with one large strip. I'm also thinking that I'll overlay the new metal on treated old with spot welds. That way I'll have the brake master cylinder mount in the exact position (it's still there but barely) and I'll have a better sense of the gentle curve from "firewall" to floor pan. All this is subject to change of course
Let's make a footwell.
And indeed I did change my plan for this troublesome area. After looking hard, I determined that trying to lap one long piece was going to be really difficult. I couldn't figure out how to really do that with all the little bends and the fact that the mount for the brake master cylinder is a little half box. I watched this YouTube video by Restoration Design and that really helped me get a good idea of what was missing... https://www.youtube.com/watch?v=3kMOMNhxg-A
So, I cut a 4" x 22" strip and then trimmed a right angle space where the tunnel joins on the right side in the old metal. The new strip was then cut four times to make flaps. The narrow flap on the left (bent up) passes between the suspension mount and the brake cylinder area (bent down). There's a large notch for the suspension mount and then a remaining flap on the extreme left to join with the wheel house. After welding this large strip in place, I fabricated a half box to lay over the brake cylinder mount. I marked the the two bolt holes, the large hole and cut those out. Then I trimmed off the sides, fixed that into place with a couple nuts and bolts and welded that in. Continuing to work from right to left, I welded around the suspension mount (front and back) and finished by tying in the wheel house and this new piece. That was the most complex with three different planes all joining and a odd curve in the wheel house. I'll do more welding and dressing in that area when I put the floor pan on. Many of the welds were impossible to grind off due to the tight quarters. I was able to weld much of the top joint front and back which should add strength. You'll see the original cylinder mount still in place behind the new metal but I should be able to carefully cut that out once I confirm correct master cylinder positioning. Interesting thing about the area is it is a part of the floor pan. The Porsche diagrams show that from the firewall forward to the front of the front trunk (including the bend over the steering rack) is ALL floor pan. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
914 resto
Goes to show you what a bit of determination can do. Do you think you should get rid of the old metal where the master cylinder is? That may just attract more moisture and rust.
With the type and amount of work you are doing, highly recommended to pull the chassis wiring harness out and reinstall it later. Get it out of your way, the reinstall is not too bad and you lessen the risk of damaging or painting the wiring.
![]() I'm kind of afraid what I'm going to find under that dash though. There was a live scorpion when I ripped out the carpets. I'll bet he's up in there ![]()
Let some light in!
Today I got the upper pad, lower pad, steering wheel, steering column, steering rack and dash assembly out. I'm glad I did! There's some rust invading the steel bulkhead below the right corner of the wind shield. Removing those parts went fairly well with no new wildlife to report
Shinny metal good.
A great day off for Christmas eve and I'm crawling through the rust
Christmas joy
You better have tomorrow with the wife or you might end up in the dog house till new year.
Merry Christmas to all Pelicanites!
Just another patch.
The wife ran me out of the house while Christmas dinner was being prepared
Tennessee Region SCCA & PCA Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend) Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11 Last edited by The Glademister; 12-26-2013 at 05:51 AM.. |
Welding on christmas
Hi
What settings do you have the welder on? I was using 1 on the power and 5 on the wire feed. I noticed it still spits and carries on when the parent metal has a bit of impregnated rust so yo will never get around that. I have got some good results by applying the spots around the sheet metal and then applying a row of spots about an inch long with about a 1 second burst on the trigger. I try to aim at the new sheet metal and end on the old parent metal. When i can see the spot go dull red I apply another spot. As you have probably worked out more then a second and you get blow through. Also applying the spots when fitting the patch is a task as the old metal just vaporises. Keep it up. Cheers |
welding fun
Yep, its not easy but what all the practice does is prepare yourself for using mig with gas. All the hard work of learning on difficult jobs is done.
We don't need no stinkin' vents!
Another evening of patching fun. Finished up the passenger side vent rust. I cut the dash bracket off with a grinder. Then marked a rectangle bending up from the previous patch. Cut the offending material out and made the patch. I actually ended up making the bends by hand and some nylon hammer assistance. The vertical welds were done in the passenger compartment and the horizontal welds from inside the fuel tank compartment. Everything cleaned up well in the passenger compartment but a bit too tight to get the grinder in on the other side.
Color me grey.
Outstanding progress today! I've got POR 15 on the front firewall
![]() Now I've been wanting to get treatment on this dash bulkhead (firewall) for weeks. After just days all these patch areas have started to surface rust and that was driving me nuts. So with this whole area mostly complete, I say the h*ll with it, and Marine Clean and surface prep everything I can get to. The temp in the garage is as good as it going to get in late Dec. so after making sure everything was completely dry, I'm slathering on the POR 15. Man, does it feel good to have that metal covered up ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Tennessee Region SCCA & PCA Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend) Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11 Last edited by The Glademister; 12-28-2013 at 07:00 PM.. |
More slathering.
Well I took a good look at the drivers side long and that side rear jack-point is okay. The plate has a rust hole but I've got the car up on the jack-point. So pulling the heater hoses out the back isn't an option right now. I thought briefly about cutting a hole in the wheel house to pull that out, but that's good metal and I really don't want to bugger up a high stress area like that. So I'm leaving that junk in the long for now. I did strip the tops of both longs, cleaned and treated. I used the last of my first small can of POR 15 and covered the tops and interior sides. I also sprayed metal prep into the passenger side long, flushed and dried that really good with a heat gun. I don't know if that will help but it certainly can't hurt either.
