Wayne (guest)
Guest
Posts: n/a
I have a 1971 914 and need to replace the ignition switch, the steering column on this year doesnt allow me to get behind and pull the wiring off of the ignition switch. Do you know the process to remove it?
This post was auto-generated based upon a question asked on our tech article page here:
Old 12-21-2013, 02:44 PM
Nick at Pelican Parts's Avatar
Good question, I cannot remember where the connector is. I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
Resident Electrician
Mike Bellis's Avatar
You cant replace the switch on a 70-71 because no one make the part. The 72-76 switch will not fit. You may be able to find an NOS switch $$$$ or a good used one.
70-71 switches are very rare now. Many guys are swapping out the entire column since the switch is NLA.
Current Project: 73 914, 1.8t, ~300hp, 930 Brakes, Roll Cage
Past Projects:
69 911, converted to C2 wide body cabriolet 3.2L
72 914, Ford 5.0L V8 EFI
Old 12-21-2013, 05:34 PM
bowlsby's Avatar
1970-71 ignition switch
Check www.CIP1.com for this switch, use the correct part number. Its in their online catalog.
Old 12-21-2013, 08:17 PM
JEM JEM is offline
JEM's Avatar
i got one from auto atlanta about a year ago they are a pita to replacewires don't unplug from switch you have to splice them in to the harness not a fun job
jerry
JM Motorsports
Custom Paint & Bodywork
81 911 SC ,black
73 914 V8 LS1
83 Audi Ur-Quattro,black
Old 12-29-2013, 02:04 AM
TR TR is offline
TR's Avatar
Isn't this what you are looking for?
NOS parts
Old 12-29-2013, 10:11 AM
