Dimensions of stuff
Does anybody know where I can get the blueprints, or diagrams for fender flares, or various other parts. The reason Im asking, is because I work in a factory where we do everything with steel, and sheet metal, and we have the machines and tools to form everything. So if I had a diagram of exact dimensions, I could manufacture me some steel fender flares. I might need to buy a set and duplicate it or something. Just a thought ....
If the shop is "modern", your best bet is to buy a set of 'glass flares and copy them with the CMM. The newer and better CMM's
(Cordinate Measureing Machine) will actually draw the part for you as you measure it from point to point.
'73 914, 1.7, with Boxster transmission in the future? ![]() |
Good idea, but I'd use a steel set of flares to use as a master set. Fibreglass is close, but still is not as good as the steel units. If you're going to go through all the trouble and expense.
Just my .02 cents
Thank you! John johnechi@hotmail.com |
I have one extra right rear fiberglass flare that I will sell for cheap if you would like to use it.
75 1.8L |
Thread Tools | |
Rate This Thread | |
