I found some foam rubber seals on McMaster Carr http://www.mcmaster.com/#rubber-seals/=q5ha9x that look like they can be closely matched. The only thing needed is the original dimensions and gluing the corners together. Should cut out a lot of the cross section fabrication without a price increase.
My seal is either not original or is smashed down so that the driver side rear latch will not stay at all and the passenger rear latch is "iffy" at best. Does anyone know what are the approximate dimensions for each part of the cross section? Using the A and B dimensions in the link above for "Style 2" cross section should avoid any confusion. Thanks!
This post was auto-generated based upon a question asked on our tech article page here:
Old 01-09-2014, 05:12 AM
Nick at Pelican Parts's Avatar
I do not know the dimensions. I opened a post in our forums. A Pelican community member may be able to answer your question
- Nick
