911 struts and hubs?
Hey guys..About a month or so ago I bought a '74 911 front end for $250.
This included very ggod condition struts, very good condition calipers, caliper harware, and adj Koni shocks. I thought all I needed was new rotors. Well to my suprise, it now seems the 911 front end uses hubs??? What is the going price for hubs and did I get hosed? Thanks ![]()
Kerry (Back on the road, sort of) 914-6 in the Werks Last edited by Va914; 09-04-2002 at 09:48 AM.. |
Well, you do need the aluminum hubs, grease caps, and bolts to attach the rotor. Hopefully you can find a set for a decent price - FYI 944s use the same.
Stay away from my Member
That is a good deal, esp if they are "A" or "S" struts (3.5" spacing) but usually the 911 setups are sold with the hubs/rotors/studs and everything all bolted together.
Do you have bare struts & standalone calipers, or the whole front-end?
Chris C. 1973 914 "R" (914-6) | track toy 2009 911 Turbo 6-speed (997.1TT) | street weapon 2021 Tesla Model 3 Performance | daily driver 2001 F150 Supercrew 4x4 | hauler |
I have the stand alone struts, calipers, shocks. I think they are M style.
![]() So the 944 shares the same hubs and hardware? Hummm. Any years I should stay with? Thanks Kerry
Kerry (Back on the road, sort of) 914-6 in the Werks |
Yeah, just wheel bearings out. Only the hub and rotor matches between 911 and 944, but that's all you need and the 944 people might not be as proud ($$) of their parts. '83 to '86
Any 911 ('65 to '89) hubs will work also. |
Thanks. I'll keep any eye out on the 944 board and 911 board for hubs and hardware.
It never endsssssssssssssss ![]() Kerry
Kerry,
Make sure your strut spindles have the little spacer rings mounted (the first thing that goes on the spindles). These rings are press fitted. Ask me how I know. Phil |
I found a set of 87's from a 944? Does anyone know if they will fit struts of a 911 '74 vintage?
In '87 the wheel offset on the 944s changed - the classic fuchs (as used on 911s and '83 to '86 944s) won't fit on an '87 or later 944. I would think the hubs would be different. My educated guess would say keep looking.
Thanks.. I'll have to pass on the '87 hubs. They were a good deal too
![]() How about 914/6 hubs? I assume they will fit the '74 911 struts.
914/6 hubs will work.
Thanks for the help guys I think I found a pair.
![]() Again thanks, Kerry
Thread Tools | |
Rate This Thread | |
