Rotor width????
Can anyone tell me the width at which a 75 914-4 rotor should be discarded and the width it may be turned at? My front rotors measured 10.1mm (0.398") before I got them turned today. Will they still be thick enough to prevent warping? I am also doing the bmw brake upgrade if this will affect it at all. Thanks, Dave
75 1.8L |
Dave,
I think every 914 owner ought to have a copy of the Haynes manual. Page 108 has all these specs. Your front rotors are going to too thin. Phil |
You can turn them one more time if they are not bad and you start with 11mm. 10mm is the limit according to Haynes; Phil is correct on that. I'm surpriised that you found someone that would turn them past 10mm. IIRC, the min is stamped on the rotor.
