chrisreale's Avatar
Re-Grind stock cam or Web-Cam?
Stock Injection on 73 2.0L. Which would provide better performance, if there is any improvement?
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 09-28-2002, 10:36 PM
Stay away from my Member
campbellcj's Avatar
I don't think you can get away with much cam and keep the stock D-Jet. But if you're gonna try it anyway, my vote would be to go new, because Type4 cams are cheap anyway. I don't know what a regrind costs but I doubt the difference is much.
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 09-29-2002, 12:10 AM
Web cam...The stock grind is very lazy and is not my choice even for astock engines, even with FI...The 73 is a great FI cam, idles like stock and pulls hard. The heads WILL cool off 15-20 degrees even with more CR.
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
www.massivetype4.com
Old 09-29-2002, 01:50 PM
3D914's Avatar
Jake,
Could you elaborate a little on the Web cam? If I read correctly, you're suggesting the "Web-Cam Stock Cam" (Lift .423, Duration 270 Degrees) for use with the stock FI system. I had understood this to be the cam for use with carbs not FI. Will this actually work as you describe?
Sorry for the speculation, it just that I'm pricing parts for a 2.0 rebuild and plan to stay with FI.
TIA,
Gerard
74-914 White - Soon to be a custom 3.2L Six 87-924S 2.5L Artic White - SOLD 74-914 2.0L Ravenna Green - SOLD
Old 09-29-2002, 02:41 PM
chrisreale's Avatar
So, the web-cam stock cam, available from Pelican, right?
3D914, ya beat me to it!!
www.914club.com
Old 09-29-2002, 02:43 PM
No, web 73, it is stock FI compatible. I use thyem all the time.
Jake Raby
Old 09-29-2002, 02:48 PM
chrisreale's Avatar
no mods necessary?
www.914club.com
Old 09-29-2002, 02:55 PM
You may find it necessary to use chromoly pushrods if the valve train geometry warrants a pushrod length change. Valve train geometry is always needed even with a stock cam.
I would advise utilizing 911 adjusters as well.
Jake Raby
Old 09-29-2002, 02:58 PM
