DavidSwedem's Avatar
Car shudders when taking off in 1st
Would appreciate some help
When moving off in 1st the whole car starts to shudder I have to depress and slip the clutch to get a smooth take off. The shudder is even worse if Im stopped on an incline.
Have sometimes a problem to get the car into 1st even when stationary and the same problem with reverse, the gears sometimes grind painfully.
Whats the problem and how do I fix it? The car is a 76 2.0
David Sweden
914 76
912 66
Old 09-07-2014, 08:00 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
As I said on the World, you have at least a couple of problems.
The grinding is due to the clutch adjustment. Adjust the clutch properly and the grinding should stop. (If it goes out of adjustment again rapidly, you probably have a clutch tube that has broken loose inside the center tunnel.)
The shudder may be due to problems with the clutch/pressure plate/flywheel, or may be due to motor mount or trans mount problems. There could be other possibilities, but those are the first ones that come to mind.
--DD
Old 09-07-2014, 08:33 AM
Dave ,
Thanks.
So the first step is to adjust the clutch and see if this helps,
I do not know how to do this. Is there a tech article some place describing the procedure.
David Sweden
914 76
912 66
Old 09-07-2014, 09:41 AM
I had this same problem. The tranny rear mounts were toast. I picked up some nice used 911 mounts for 20 dollars. After replacing car works fine. Also the original mounts looked fine from the outside. Once u pull them out the center just dropped out
Old 09-07-2014, 11:27 AM
Thanks for the advice, I will pull them out and have a look.
What year 911 mounts did you use?
David Sweden
914 76
912 66
Old 09-07-2014, 12:14 PM
Administrator
You adjust the clutch by loosening or tightening the nuts on the transmission end of the clutch cable. There is a specified amount of free-play at the pedal end, and that free play is wholly or partly measured by pulling up on the clutch pedal. (There is a spring that pulls the pedal forward and takes up the free play.)
--DD
Old 09-07-2014, 04:36 PM
Also check the front engine mounts. If the rubber breaks down and the mount is in two pieces your engine is only being held in place by gravity. Slowly and gently jack up the engine to see if it lifts off the engine bar.
Old 09-07-2014, 05:29 PM
Thanks,
I will check the engine mounts
David Sweden
914 76
912 66
Old 09-09-2014, 06:49 AM
porschetub's Avatar
Could the clutch plate be oily by any chance,just saying
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 10-02-2014, 10:46 PM
Certified Porsche addict
The Glademister's Avatar
Perhaps. I've seen motor oil in Boxster and Cayman trans from rear main seal or IMS cover leaking. On those it drips down to the bottom of the bell housing and pools with the clutch dust. That will keep it from showing up on your garage floor until the leak gets really bad. I'm not sure if that would be the case on a type 4 or not.
Tennessee Region SCCA & PCA
Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend)
Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11
Old 10-03-2014, 07:19 AM
