dave blackburn's Avatar
MSD, new coil and ignitor.
Well I just finally my msd 6a, blaster coil and pertronix ignitor installed. What a difference. It is about -15c here today and it starts as soon as I think about touching the key! I can notice a big difference in power and smoothness. Overall a well spent 250$ from the local buy/sell. Dave
75 1.8L
Old 11-10-2002, 12:30 AM
Zeke's Avatar
That's exactly what I'm using. Haven't got to try it yet. But alot of people I talked to have confidence in the setup. Later on, I might get the Mallory. BTW, Crane makes a CD like the MSD for a little less moolah.
Old 11-10-2002, 05:02 PM
John Rogers's Avatar
That's the same setup I use on the big 4 racecar engine. It has been great for 4 years now and shows no sign of stopping. I get 15000 volts at the plug at idle and close to TRIPLE that at 6000 RPM! I bought a Snapon secondary voltage tester so I can troubleshoot ignition problems since my multi meter does not go that high.
Old 11-10-2002, 08:47 PM
Bruce Allert's Avatar
What is this msd 6a, blaster coil and pertronix ignitor??? Is it for stock engines? How do I find out more? I'd like to have one.
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Gotta mow the Lawn...
Old 11-10-2002, 09:16 PM
Bruce, the MSD 6a unit is a multiple spark/capacitance discharge ingition module. It supplies around 400v to the coil instead of 12v which means a higher voltage/hotter spark. It also fires multiple sparks over 20 degres of crank rotation to burn all the air/fuel mixture. The blaster coil is just a high output coil and the pertronix ignitor will replace your points and condensor with an electronic module. I think all the stuff new would be around $450us, but I found some good deals on e-bay and in the local buy/sell. I got every thing for around $175us. Very easy to install, but you must get the MSD tach adaptor. www.msdignition.com ,Dave
75 1.8L
Old 11-10-2002, 10:01 PM
One more thing.., My engine is a stock 1.8L, so yes it is for stock engines, Dave
75 1.8L
Old 11-10-2002, 10:03 PM
thanks Dave, sounds like a good Christmas present!
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Old 11-10-2002, 10:30 PM
sacook's Avatar
While your at it....the Unilite distributor can't be beat for this application also..
Old 11-11-2002, 05:19 AM
To complete the systems use a MSD distributor and plug the 6 Al directly into the distributor. Use MSD wires as MSD is picky on the kind of plug wires, Summit sell both plug sets and distributors. (They're sold as VW parts)
Old 11-11-2002, 06:56 AM
canna change law physics
red-beard's Avatar
ANY C/D unit will be an improvement over the stock ignition, plus if you do stay points, they will not wear out (except mechanically).
I put an MSD unit into my 6 (which had a CD unit already) and with the carbs it is better in the low rpm zone. Remember, above. 3000 rpm, there will be only 1 spark per cycle. MSD only helps from about 2500 and DOWN....
James
James
Red-beard for President, 2020
Old 11-11-2002, 07:30 AM
