Steering Column Problem
Well after several hours of eliminating why my 75. 914 1.8 wouldn't crank I found that the ignition switch was bad. Replaced the switch and cranks perfectly; however, during the process of disassembling the steering column I pulled the steering wheel shaft out of the "fixed" sleeve and I can't get it to go back in place so I can reinstall the steering wheel. What am I missing???
That crush bush should be fitted into the top bearing from the back,as you already have the "C" clip off fit the bush back into the bearing first it should then go on together,will check mine and edit if required...she how you go,cheers.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
Thank you, any help would be greatly appreciated!!!
