Anyone running "Nickies"?
I've got a couple of years (hopefully) before I rebuild, but I was seriously concidering getting a set of the "Nickie" cylinders and pistons kit from LN Engineering (http://www.lnengineering.com/) possibly the 102mm. $2800.00 seems like a chunk of change for an engine kit, but if they work as well as advertised I guess it would be worth it in the long run. So.............. is Anyone running Nickies?, if so, what's your opinion on them.
Save the Whales......................Collect the whole set
"Whether you think you can, or think you can't, you're probably right" - Henry Ford '73 914 '75 914 |
Ayup, I'm runnin' nickies.....they come from Mahle...the pistons from Shasta. They seem to work pretty well.
As for the cost, you pays your money and takes your chances.
JPIII Early Boxster |
I'm not running them but the LN Engineering guy Charles Navarro is a regular here. Not only do engines with Nickies last forever bit they run very cool.
Give Charles a call and he will give you the rundown. He's a good guy.
Chris H. '75 914 3.3 |
914 Geek
The Biral (iron liner, aluminum fins) cylinders also look pretty interesting. They were even more interesting at the price point that had been discussed earlier (as in, "we think it will be around $$, but don't count on it") but they may still be a decent way to go... Still, $1000 for a set of cylinders is a big chunk of money.
Hey, if they work the way they are supposed to, either setup is well worth the money! --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Birals and Nickies work, I'm using them more and more everyday. Nothing parallels them.
Jake Raby Owner, Raby's Aircooled Technology www.aircooledtechnology.com www.massivetype4.com |
$1000 for P&Cs too much?
Try looking at new Mahles for a 911, especially fancy ones, like 98mm P&Cs from Andial with 9.5:1 CR, optimized for carbs.... Cost around $3K. I realize you're getting six, instead of four, but still.... sheez! But $1000 for P&Cs in a higher performance Type IV engine that you want to run cooler and hold together is a great investment, IMHO. Talk with Jake... he knows his stuff! Plus he likes to blow up engines for fun! That's cool! Happy Thanksgiving... Regards,
Qarl |
Yeah, they sound like the way to go to me too. I've got two extra 2.0L short blocks laying around, and plan to slowly (so that the wife doesn't catch on) over a two year period convert one of them into a 200+ hp "Nickie" powerplant. Just need to locate someone around these parts that does descent head work. The last place that supposedly rebuilt my heads was pathetic, I got them back and they still had the old exhaust gaskets stuck in them, and upon removal I found part of the gasket boss missing, real precision work there (not!).
NOTHING parallels Nickies, only Birals even come close.....
Infact if you want me to assemble any engine with a bore larger than 96mm, you gotta make the investment with the Nickies, I won't even contemplate cast iron cylinders.....too much work, too much cost for a life of only 20K miles if you get really lucky.
914 Geek
Try looking at new Mahles for a 911 Actually, that's $1K just for the cylinders. The "cheaper" ones, the birals. If you compare apples to apples, it's $2400 for the Nickies P&C kit. A wee bit more per pot than the 911 set, though the materials are comparable. (Laws claims that the Nickies are actually better material and a better design; I don't know enough engineering to agree or disagree with him.) --DD
The biggest problem I see running them is the rest of the engine. Investing into a nice set of P/Cs will also incure the cost of making damn sure that nothing else is going to come apart and turn them into hammered sh....! I would probably light the car on fire and send it off a cliff if it dropped a valve after investing in a set of LNs aluminum P/Cs. Spending money on quality parts in no problem for me, its the time it take to get that money that makes it hard.
HAPPY THANKSGIVING
Exactly, and when I use a set of them nothing is spared, Billet cranks and all the finest parts are standard, you don't have to have them but I'll be damed if something is gonna screw up those cylinders!
Dave!
Oh crap! They ARE expensive. But I'm sure they're better than big bore P&Cs from Japan! You get what you pay for! Happy Turkey Day! Regards,
Qarl |
