Thanks.. but one more question...
For those who have been following with my seemingly broken-down car..
Really good news guys.. I was stressing for nothing. I just finished a drive up to San Jose from Pomona.. and found out, like my fuel level sender.. my temp sensor must be off too.. because it heated up to *near* red before i started the climb over the grapevine, i was very worrysome and was ready to pull over at any second if it went any further, but it never did. in fact.. it started dropping as i topped the big hill.. never lost performance.. passing people up left and right. I kept an eye on the gauge the entire trip up, but not one single problem (and i was getting 25mpg!)... Long story short.. the car works great, just need to contact tom and wayne about some new senders. with every good story though, there seems to be a bad that comes along (at least with me). I found out that i have a crack in my hose that runs to the rear, driver-side fuel injector, the hose that connects between the injector itself and the fuel rail. it was a small crack, very little leakage, but can definitely smell it. My guess is the long distance stress was a bit too much for the old hose. I've taken the injector off, cut the hose partway, and rigged up a pretty sturdy hose, but it's far from good. My question is: is there anyway to remove just the hose (the little elbow piece) off the injector?.. It's clamped on there real tight, and i didn't feel like taking my chances breaking the injector by using force, that'd mean being stranded up here for a while. or am i just stuck with buying a new injector to fix the cracked hose?.. Thanks, Jeff |
RETIRED
Jeff,
If you are talking about the crimped on brasslike fittings on the injector, they can be ground off with a bench grinder. Carefully, grind through the metal at the base an remove the casing. Oh yeah, remove the injector from the engine first....;^) Re-install FI high pressure hose and securely clamp it. BTW-When ordering a new oil temp sender, get the matching gauge with numbers. The old gauges are junk, you will never find a sender for the old gauge and the price difference is not much. [This message has been edited by mikez (edited 08-22-1999).] |
