NPC- Challenging Volvo FI problem, need help
We have had an odd problem on 3 different Volvos,
14 years apart. The first car was a 1978 240, the second car was a 1987 740 turbo and now we are troubled by a 1992 740 turbo. The ’78 had CIS while the 742’s have KE Jetronic. The problem in the '78 was solved by the crusher, but somehow, we managed to fix the ’87(which I still have as a parts car (I live in new Hampshire and feel the need to have a few)). I need help with my ’92. Because I have had this problem in 3 of the 4 Volvos that I have had, I assume that it is very common. The Problem… Sometimes the problem comes on while driving but usually begins when the engine is first started. It will idle fine, and accept a little throttle but if the throttle is opened more than a certain amount, the engine bogs down as though it is running out of gas. If the throttle is closed then the engine smoothes out. Now the Strange part. If the ignition is turned off, and then on again, power is instantly restored. I don’t even have to shut the engine off completely, just, click off, click on. So we replaced both fuel pumps, mass airflow meter, fuel pump relay, plugs and wires. It feels like a fuel delivery problem to me but I am not ruling out ignition. What parts are common to ’78 CIS and KE jetronic? The only thing that I know of on the FI side is the fuel pump relay. I don’t recall what the 78 had for ignition. What parts are affected by toggling the key? Has anyone seen this before? Any ideas? Thanks for reading this far. -Brett Anderson |
A 92 740 Turbo should not be KE jet.
(EDIT my WAG would be CTS) (EDIT #2 Ignition switches are also a known problem) Go here: http://www.brickboard.com/ Look at the "700-900 FAQ" Its bailed me out EVERY time. http://www.brickboard.com/FAQ/700-900/ (90 744t)
Robert 1975 Porsche 914/4-2.0 1972 Ford F100 Ranger XLT 2006 Ducati Sport 1000 323i.net RangerXLT.com Last edited by DuckRyder; 01-10-2003 at 07:01 AM.. |
