blinkers won' t work after switch to ledbulbs
Hi there,
I've recenttly changed my lightbulbs from ordinary to led were possible ( parking light and turn signal).
Since then my emergency warning signal, witch puts the four turn signals in action, works fine, but when I try to engage my normal turn signal ( left or right) I have no reaction. The turn signal relay doesn't seem to go, and the fuse is OK, as it goes with the wiper blades etcetera.
What could be the cause?
Thanks in advance for Your reply.
Marc
Zele
Belgium
Old 05-02-2017, 07:38 AM
Control Group
Tobra's Avatar
Maybe the LED does not draw enough electricity to get the relay to do its thing
Old 05-02-2017, 12:53 PM
Yes you probably need to add an inline resistor or swap the relay. Old relays and LEDs dont play well together.
Old 05-02-2017, 10:03 PM
https://www.superbrightleds.com/moreinfo/flashers-load-resistors/cf13gl-02-led-bulb-electronic-flasher/782/836/
Of course, it doesn't have a pin for the dash lights, so I can't see that the turn signals are on...but otherwise plugs in and works fine.
Old 05-04-2017, 07:35 AM
porschetub's Avatar
Never had that issue with mine ,would expect your flasher unit is kaput,sorry.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 06-08-2017, 02:58 PM
