Hoses behind turn signal switch
While removing the turn signal switch on my 75 914, I noticed there are two rubber hoses attached to the back side of the switch along with the usual electrical connector. What are these hoses for? Thanks.
Old 02-25-2003, 10:51 AM
Sounds like the windshield washer system to me. 914s had this freaky deal where a tube went from your spare tire to the steering column to the fluid bottle. When you pulled the switch, air form the tire was used to spit fluid on the windshield. Great until your tire went flat.
I think people have been retrofitting 924 electric pump systems for a couple of years.
Kevin Taylor
'75 Silver 914 1.8
Atlanta, GA
Old 02-25-2003, 11:02 AM
...or until the tube at the switch splits and dumps the washer bottle contents on your legs!
Mike
Old 02-25-2003, 12:25 PM
Kenny Powell's Avatar
Hey Maw, it's the Plumbing again!( c'mon you guy's
75' 2.0 w Ljet
"I like the way she doesn't move in the curve's... and then she let's go!"
Old 02-25-2003, 12:32 PM
kellzey's Avatar
DON'T TOUCH THE HOSE! Those feed the energy from the flux capacitor to the engine.
No.. those are for the pressure fed wiper system.
Regards,
Qarl
Old 02-25-2003, 12:33 PM
Potter's Avatar
Send a message via AIM to Potter
There's nothing worse than your hose leaking on your pant leg.........
Well...SOMEBODY had to say it.......
'73 914 2.0
"Seriously Honey, the part was really really cheap...........honestly"
Old 02-25-2003, 12:37 PM
If the system is working properly, there is supposed to be a valve that makes the washer not work if the spare tire drops below 29psi.
HA, yeah, right.
I've seen to many 914's with clean windshields and flat spares to see the flaw in that system!
Don
Don Kiepert
'73 Big Bore
'02 GTI 1.8T
Race a Porsche - There's more to life than left turns!
Old 02-25-2003, 02:21 PM
It seemed like a great idea- on paper.
Old 02-25-2003, 02:56 PM
It can also cause your spare tire to suck in windshield washer fluid if the check valve is bad. Then you go to use the spare, and the vibration will shake your teeth out until you get the water out of the tire.
BTDT... and it's in an old copy of Upfixin Der Porshce.
Clay Perrine
74 914 1.8L (Frodrick)
73 914 /6 4.0L 964 motor (Igor)
70 914 /6 Factory Six. (Elwood)
95 BMW 540i (Inga)
Old 02-27-2003, 01:48 PM
914 Geek
It also makes for a really good Tech Quiz question! One that stumps just about everyone who takes the quiz. Including some long-haired Calfornian....
--DD
Old 02-27-2003, 02:06 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Clay, what is the correct part number for the 924 switch. I tried this last year then gave up as none of them fit.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 02-27-2003, 04:57 PM
M. Hendrix's Avatar
They do fit, but it requires a weird magic incantation that I can't remember right now.
There is a tech article about this somewhere.
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 02-27-2003, 06:07 PM
Peter_Hinkle's Avatar
Send a message via AIM to Peter_Hinkle
My local flaps had a aftermarket pump called a "superpump" which sounds like a porn movie yet works pretty well. Installs in minutes and utilizes the original bottle and lines..peter
Peter Hinkle
drumvudu@earthlink.net
http://home.earthlink.net/~porsche914
1974 Saturn Yellow 914/4 1.8/w BigBore/Webers/MSD
1988 944 Black on Black w/phone dials
Old 02-27-2003, 08:44 PM
Ron Meier's Avatar
You mean you drive the teener slow enough for things to stick to the windscreen?
"Inventor - Blue Flame 914 Seat Heater"
"Yellow Rusty Cars Are Faster"
_____________________________
'70 2.5 (I'll never finish it - Somewhere over the rainbow.....,)
'73 2.0 (Just Not The Same)
'74 2.0 (Heartless & Lungless)
Old 02-28-2003, 05:43 AM
drive the teener? huh?
Old 02-28-2003, 07:48 AM
Bleyseng's Avatar
I tried the tech article and that part wasnt going to fit unless I used a BFH! Way to big.
Geoff
www.914Club.com
My Gallery Page
Old 02-28-2003, 09:30 AM
The part number for the 924 wiper switch is "111 953 519 G" When you get it, you will have to change the plastic wire guide for it to the one from your original wiper switch. It has an additional circuit for the washer pump, as well as the connections for the hoses for a 914 washer. You can remove the hose connections, but it's not necessary. Just jumper one of the switch wires to the power for the wiper motor, and put the other on the connector that is above the plane of the plastic switch connection. That will connect it to an unused brown/white wire that is sitting by the wiper motor. Then just hook the washer pump to that wire, and connect the other side to ground. If you did everything right, you should be able to pull the switch and hear the pump run.
Clay Perrine
95 BMW 540i (Inga)
Old 02-28-2003, 01:44 PM
