wipers question/problem
when i hit a bump or use the turn signal, occassionly the wipers will go on for a single pass then stop. Any clues on how to trouble shoot/repair this? Is it likely its the relay?
Old 02-25-2003, 08:27 PM
Ornery Bastard
I've heard that this is a fairly common problem with the 924 and that it's generally caused by your switch being corroded.
The 924 switches look quite similar to the 914's, it could be the same problem. Try cleaning the switch and its grounds.
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 02-25-2003, 08:36 PM
Peter_Hinkle's Avatar
Send a message via AIM to Peter_Hinkle
Tod, I remember reading the exact cause and solution for your problem in the tech tips book that that darn hussey down in georgia wrtoe. I am not with my book right now but when I get in I can look it up if you like or if someone else has it available, will ya take a look? peter
Peter Hinkle
drumvudu@earthlink.net
http://home.earthlink.net/~porsche914
1974 Saturn Yellow 914/4 1.8/w BigBore/Webers/MSD
1988 944 Black on Black w/phone dials
Old 02-25-2003, 09:00 PM
thanks i appreciate the help.
Old 02-25-2003, 09:22 PM
philinjax's Avatar
If you have intermittant wipers (flick wipe), Hussey's 700 tech tips says the problem is a loose lower left grounding screw on the wiper switch assembly under the steering wheel, what ever that means.
Looks like you might want to pull the wheel and see if you can find anything loose in there.
Good luck,
Phil
Old 02-26-2003, 10:45 AM
