Driver
Different types of temp units?
Hi,
In a separate thread I posted that my temperature control unit had a broken base plate and was missing some switches, so I decided to buy another used unit that had and then send them to a rebuilder who could essentially cannibalize one to build out the other.
I got an email from him yesterday that said that the units are in fact different. Here is what he wrote
"these are two differently constructed units. I'm not sure what that means exactly. The more beat up one only had 1 circuit board in it. The better condition one, had three in a U formation. "
Does does anyone have any information about differently constructed units? I purchased a unit that was said to have come out of a 1987 base 944 which is my car and what my unit came out of.
It appears the connectors and the receptacles on the back of both units are the same.
As always thanks in advance
GHEN
Old 11-16-2019, 04:02 AM
There are 2-3 versions of the 1985.5+ AC climate control head. They all look more or less the same when installed. The early one has a ton of boards and components and is bulkier, I think it also has the non-replaceable AC switch. The later one has a lot more integrated circuits and a socketed AC switch. 968s get a detent pot for the temp knob. I'm running a 1988 Turbo unit in my 1992 968 and it works fine, seems the same other than the detent clicks when rotating the temp knob. It's the more integrated type.
I do not know when the cutoff for the old-timey multi-board unit was.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 11-16-2019, 07:33 AM
Driver
Originally Posted by Jfrahm View Post
There are 2-3 versions of the 1985.5+ AC climate control head...
Thanks!
GHEN
'87 944
Old 11-16-2019, 09:02 AM
