Tips for spark plugs removing & installing ect
Here are some tips for removing spark plugs & installing without damaging them,losen them first with ratchet & socket then use a rubber hose to remove & install afterward then tighen to specks.Oil filter shove some paper towels down & around it...will keep it from being messy ,disconect the coil cable ,use filter remover with a long extension & ratchet.Install back by hands.For those who have fancy wheels & nuts & don't want to damage them this socket with with interior softener is the answer.
![]() ![]() ![]() ![]() ![]() Take be safe
Caraquet,N.B. Canada. |
curtisr
+1
1977 924 Guards Red (parted and sold) 1987 924s Alpine White (sold) 1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold) 1987 924s Garnet Red (currently becoming Lowencash II) 1982 928 Silver (sold)
Yes...I could see that after loosening a spark plug too much lateral (sideways) pressure could then damage threads - so your suggestion to use a rubber tube to remove them after first loosening and then to install them before final tightening sounds good. Thanks!
Thanks Ernie, all these little bits of collective wisdom add-up to make us all smarter.
I'd also suggest a small dab of anti-seize on the plus threads. Some sources recommend against this but in my 30+ years of playing with cars, that's always proved a good idea. Many of those thirty years were spent playing with Alfa's, which score 10/10 for "Ease of Changing Plugs" ![]() Not my Alfa John |
Sent from my SM-N950U using Tapatalk |
Patrick
I don't bother applying anti-seize since the plugs get replaced often (every other year)...
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
Some car MFG’s say no to anti seize on plugs due to a concern about it harming conductivity. I’ll likely never be working on a car that modern.
One important first step is to use compressed air to blow out any dirt in the plugwell before removing the plug so nothing can fall down inside the cylinder.
Also finish the job with a torque wrench. |
Reviving an thread of mine ,was thinking it will come handy for new guys which have just join us.Adding a couple pics ,first on notice the rubber acting as softener inside the socket for plugs removal & a wheel wrench I modified from + to T,work real good,both of my Porsche.
Nice tool. I have found that using only a socket and an extension (no ratchet) to start the plugs in their holes is the best way to ensure that the plug is not cross threaded. Once it reaches the bottom of the hole, I attach the ratchet and give it a snug.
I am a firm believer in antiseize, use it on all my cars, old and new.
Good luck, George Beuselinck |
Not sure if they come in two dimension ,the one on my 944 was 22x27x1.5 mm can you shed some ligth on that George.
Will keep on going with more infos,not for the old timer but the new members,hate to call them Newbie or Green:
The two next pics will show you the rigth level to have on your oil dipstic.... Bleu straw full....red don't start your motor unless you add oil. second pic Black mark your ok to drive but should top off.
![]() can happen to the best
944 S2
Great tips!
Now if only we could figure out how not to dump oil all over the place when removing the filter! |
Awesome info, @Ernie944. Will definitely use the rubber hose tip for the Porsche plug change. Keep'em coming.
@Jjefferies is absolutely right about Alfas -- doesn't get any easier on those beautiful engines... except trying to find a source for the recommended Golden Lodge spark plugs is a massive challenge. The Alfa guys will know what I'm talking about!
Stephen 1987 924S 1974 Alfa Romeo Spider 1973 Ford Courier |
+1 on this also you can turn a plastic shopping bag inside out put your hand in it like a glove then finish unscrewing the filter and quickly flip it up into the bag for a less mess easy disposal...easy peasy!!!
944 addict
Does anyone make an adapter for a remote oil filter?
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
Give Linsay Racing a try.
