universeman's Avatar
When do both cooling fans run?
my 968 regularly has one of the two cooling fans on, but rarely both. seems wrong. Hows it supposed to work?
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 07-31-2020, 10:25 AM
9FF 9FF is offline
9FF's Avatar
Second fan will run:
1. When the AC is on, or
2. When the upper temp is reached by the coolant temp sensor on the radiator, or
3. When the AC high-pressure sensor by the dryer is activated.
Old 07-31-2020, 10:31 AM
Thanks!
Old 07-31-2020, 10:00 PM
Just thinking out loud
mattdavis11's Avatar
Just adding on to 9FF
or,
4. When you have a bad thermo fan switch. (on the radiator).
91 FJ80
84 Ram Charger (now gone)
Old 08-01-2020, 07:57 AM
If you need help, I'm in the area.
91 FJ80
Old 08-01-2020, 08:00 AM
Misunderstood User
Originally Posted by mattdavis11 View Post
just adding on to 9ff
or,
+1
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 08-02-2020, 12:06 PM
When I turn off my 84 the drivers fan funs slowly for a while.
Is there any timer associated with this so the fan doesn’t run out the battery?
I have seen it keep running for a couple of hours which seems excessive. I believe someone installed a lower temp radiator thermoswitch which is a factor but seems like there should be a feature that will turn them off eventually.
Old 08-02-2020, 05:26 PM
9FF 9FF is offline
9FF's Avatar
The coolant temperature sensor in your radiator is bust, it’s supposed to tell the fan relay to turn the fan off when the engine cools, usually a few minutes at most.
Old 08-02-2020, 06:21 PM
Thanks a lot. My low speed fan ran for 24 hours and drained my battery. I guess you are right and switch is frozen in closed position.
I will have a new switch soon. Any tricks to remove/replace? Is it easier to go from the top or from the bottom?
Old 08-03-2020, 03:02 PM
Top. Don't over tighten it as the plastic end tank may crack.
91 FJ80
Old 08-03-2020, 03:11 PM
9FF 9FF is offline
9FF's Avatar
...Any tricks to remove/replace? Is it easier to go from the top or from the bottom?
The switch is on the radiator and easy to get at from the top. On an na I think you just need to remove the air box and use a deep socket and short extension. You’ll lose some coolant, not much, just have some rags handy and the new sensor ready to swap in.
Old 08-03-2020, 03:15 PM
Thanks for the tips. I was able to get to the switch after removing the airbox and was able to work around the coolant hoses.
Old switch was a Wahler low temp that was probably 7 years old, per previous owner records. I replaced with a higher temp switch. The low temp switch had the fans funning almost constantly. It would really drive me nuts in the winter when I would drive around the block in 30 degree temps and the fans would come on as I pull into my garage.
Old 08-06-2020, 05:06 AM
9FF 9FF is offline
9FF's Avatar
Don't forget that your coolant temp switch is matched to your coolant thermostat. A 71 thermo uses a 75 switch and a 80 thermo uses an 85 switch, but i guess as long as the switch is higher than the thermostat then all should be good. Just don't go fitting an 80 degree thermostat with 75 degree switch.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 08-06-2020, 11:32 AM
FWIW, my pass side fan is blowing fuses. I have a replacement fan in the garage, going to swap it in today. Don't forget to check fuses, folks.
Jason - Austin, TX
92 968 coupe
Old 08-08-2020, 06:41 AM
Swapped out fan. Engine stays much cooler now. (Imagine that!) Anyway just closing the loop for others who might be dealing with fan issues!
Jason - Austin, TX
92 968 coupe
Old 08-09-2020, 07:55 AM
