gearhead290's Avatar
Send a message via AIM to gearhead290
Question A few questions
I have found a 951 engine and it is in need of some parts. I just odn't know if I can use the ones I already have or if I have to use something different.
1) Are the throttle bodies between the n/a and the 951 interchangable?
2) Are the wiring harnesses interchangable?
3) I doubt this one, but are the mass air meters interchangable?
4) If I run the n/a injectures will I have fuel problems?
5) Kind of a stupid one here, but are the vacuume hoses the same?
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 05-02-2003, 03:14 PM
One big NO!
Old 05-02-2003, 03:49 PM
Scott R's Avatar
You can use the long block, but why would you want to? The Turbo has dished pistons for compression, you would be loosing power putting all of you're NA hardware on it.
I used a Turbo long block in my supercharged project. All of the NA intake parts and such bolt on. But all of the stuuf that you mentioned is not interchangeable.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-02-2003, 04:12 PM
I have found a good deal on a turbo engine with everything but the parts I mentioned. That's why I"m curious, somethin tells me that I have a smaller throttle body and my runners on my intake are different correct?
Old 05-02-2003, 04:44 PM
Correct.
Old 05-02-2003, 05:00 PM
Roger Hall's Avatar
Cant imagine that the wiring harness is interchangable.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 05-02-2003, 06:34 PM
Scott R's Avatar
It's not. The 951 TPS has a different connector, also the lines for the cyclic valve, not to mention the added wiring for the KLR.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-02-2003, 07:09 PM
Will my n/a injectures work with the turbo motor or will I be too lean?
Old 05-02-2003, 09:00 PM
Roger Hall's Avatar
I belive your injectors are rated to something like 300 hp they might be fine.
Roger Hall
81 924 N/A
Old 05-02-2003, 09:04 PM
anybody know how much the n/a injectures flow and how much the turbo injectures flow?
Old 05-03-2003, 08:02 AM
No way, you need turbo fuel injectors, the factory turbo ones aren't good past 300rwhp
Old 05-03-2003, 08:20 AM
